Question about Sharp Aquos LC-22SV2E 22 in. EDTV-Ready LCD Television
I have a problem with a Aquos Sharp LC-22SV2E television. The problem is, once you plug in the TV, it will not power on. I've removed the cover, and have discovered that, what appears to be a resistor near chip IXB427WJ, is glowing red, off of the top left pin when looking at the circuit board, I have pictures. Does this indicate a problem therein with the chip or the resistor unit? Does the entire section need to be replaced? Could the problem be something else? Does the object that's glowing actually always glow? It looks like it's burned or something on it when I put the TV in the off position. Any help and I would be grateful. Thank you. (Board 295998 V1.1 / KD 375 WE015NM
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
skotkolr
  • 558 Answers
SOURCE: sharp lc-37 AQUOS
in my experience red tinting is from failing cf tubes(the light tubes that make the tv come on). a repair or replacement of the cold florescent tubes is called for inside the lcd unit. how old is the tv?
Posted on Apr 28, 2008
circuitworld
  • 335 Answers
SOURCE: sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Posted on Dec 01, 2008
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
  • 1779 Answers
SOURCE: power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
Posted on May 17, 2009
Will my sharp aquos lc22sv2e accept digital signal ?
Sharp AQUOS LC 22SV2E Operation Manual
Try this link to download its user manual. Its specification page will give you all details about its performance.
Gopakumar Gopalan Google
May 23, 2014 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Hi i need the panel remote board for sharp aquos lc-22sv2e and the remote
Contact the nearest authorized service center for Sharp at your town.
Oct 11, 2012 | Televison & Video
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I've lost my TV remote. How do you manually turn 0n the power for the shar Aquos
The power button is on the top of the tv on the right along with the channel, volume and input button.
May 26, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need a power supply for sharpe aquos lc-22sv2e
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 03, 2011 | Sharp Aquos LC-22SV2E 22 in. EDTV-Ready...
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-22SV2E 22 in. EDTV-Ready LCD Television Logo
53 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
