Question about Whirlpool Refrigerators
My icemaker will no longer make ice.. iT JUST STOPPED ALL OF A SUDDEN.
    President:
  • 1,218 Answers
Good day,
There are a few problems that can cause an ice maker to quit. First, it's important that the freezer be at normal operating temperature. If it warms above 14 degrees, the ice maker is designed to lock out completely.
If the freezer temp has remained normal then follow thru with these steps. It will get you there.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jul 10, 2010
WILL NOT MAKE ICE
1. Turn the water on with the valve in the back of the refrigerator.
2. Make sure the filter is not clogged.
3. If it has made ice regularly and all of a sudden stopped you may have a waterling frozen goibg to the ice maker.
4. Other problems make be a bad solonoid valve and no wate ris sent to the icemaker.
Jul 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
Jun 04, 2009 | GE GSS25JEMWW Side by Side
In the door ice maker has stopped working. the light controller s
when you look at this icemaker there are 2 sets of strippers 1 stationary the other moves. teh one that moves is normally at 2 o'clock position facing the front cover of icemaker. if these teeth are in anyother position for longer than 10-20 minutes then you most likely have a bad motor module on the icemaker, this is a very easy repair you will need partnumber 8201515 from whirlpool or local appliance supply house. thx peyton
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ice box stopped making ice
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Dec 26, 2008 | Refrigerators
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
Ice maker stopped working
Just a question... Is the motor that flips the ice down into its tube moving? or spining? your motor in the ice maker may have went out. might have to replace it.... hope this helps....
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
