Question about Garden
Husqvarna 67521ES 6.75 self starter mower won't start. I have changed the filter oil and spark plug. Why won't it start?
  • 71 Answers
You may need to replace the points and on that particular model it is a very difficult process that is better left to a professional.
Posted on Jul 10, 2010
Several year old husqvarna self propelled riding lawn mower seems like running on one cylinder. Will run, but goes very slow.
1st, check and replace spark plugs as necessary, then check your plug wires. And don't forget to check your fuel and air and oil filters and oil level. How old is the gas? with luck, you've only a simple maintenance problem.
Jul 04, 2014 | Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
My husband has a husqvarna self propelled mower that was running great and now all of a sudden it will not allow him to pull the string to start it? I believe the model is gcv190? Do you think something...
the problem with tilting the mower on its side is that you put oil up in the carburator.that makes the needle let dirt through it.remove the spark plug and pull the recoil a few times until you do not see any more fuel comming out.once all the fuel is out of the cylinder,reinstall the spark plug,chech oil level.you should change the air filter.it probally has oil in it and will make the engine not run right..start the mower and let it run awhile.the problem shoul clear it self up.if it happens again you will have to clean the dirt from inside the carburator.hope this helps let me know...................
Jun 06, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Yard Machines 22 inch mower, I dumped it on its top over the weekend, bent the blade, replaced it, now wont start, did leak oil out of the air filter, cleaned it out real well still wont start
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
