Question about IFS EtherNav D7600 8-Port Ethernet Switch (D7600-VV-S)
VLAN hi I am trying to configure a VLAN using 3 ethernav d7600 switches and i connected to them 1 DECT3000, 1 DECR300 , and 2 DED2500 so basically 2 contactors and 2 converters can anyone help me on how to configure the VLAN ? thanks
  • sameriek Apr 23, 2008
    cmon guys !!!
    no answers here ?????
How do you want to configure it? Are you looking to divide the Terminal Server into one VLAN and the DECT unit to another?
I would just recommend setting them via physical port ie put the terminal server always on port one and the other on port two. Be aware that the D7600 always has to have a VLAN1 as standard with at least one port dedicated to it.
So From the main screen
Advanced Management --> L2 Switch Database --> + (Create) --> VLAN ID (hit enter) --> VLAN ID (enter a number like 2 or 3) --> VLAN Name (like "Terminal Server" etc.) --> Hit Esc until you go back to VLAN Perspective --> Choose the newly named VLAN --> VLAN Settings --> Hit + --> Choose Untagged Port --> Choose Port 2 --> Hit Esc Until you get to main menu then save it.
Do the same for your next port and mimic the settings on all of the switches.....Hope this helps
Posted on Jun 10, 2008
No competent guys out there ???
Posted on Apr 26, 2008
Does the Switch Support QinQ?
· The S2700EI supports only basic QinQ configured using the port link-type dot1q-tunnel command, and does not support selective QinQ configured using the port vlan-stacking vlan command.
· The S2700SI does not support basic QinQ or selective QinQ.
· Other models support both basic QinQ and selective QinQ.
Jun 01, 2016 | Huawei Computers & Internet
There r three companies: company A, a branch of company A, and company B, they r connected using switches. To implement dynamic VLAN registration, enable GVRP. The branch of company A can communicate
You can follow the below steps:
1.Enable GVRP to implement dynamic VLAN registration.
2.Configure GVRP on all switches of company A and set the registration mode to normal for the interfaces to simplify configurations.
3.Configure GVRP on all switches of company A and set the registration mode to fixed for the interfaces connecting to company A to allow only the VLAN to which company B belongs to pass.
You can get into for more details.
How to Configure GVRP for Huawei Switches
Nov 04, 2014 | Huawei Computers & Internet
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
Sir I have 4200 series 26 ports Switch i want to Configure intra VLAN But I am Getting a problem to Configure that switch . After Cnfigure VLAN on Consol prompt. I am not accessing to my Server & WAN...
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Nov 01, 2010 | 3Com 4500 24-Port Ethernet Switch
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 - 192.168.105.12"
flow-control
exit
interface 50
name "Uplink to HP2650 port 49 - 192.168.105.13"
flow-control
exit
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address 192.168.105.11 255.255.255.0
ip helper-address 10.50.3.2
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
ip address 10.50.3.11 255.255.255.0
tagged 1-46,49-50
exit
ip route 0.0.0.0 0.0.0.0 192.168.105.1
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Mar 27, 2009 | Zyxel IP Express IES-1000 (91004098002)
Connection error
can you clarify the switch configuration, by default it will have all ports as untagged in the default vlan 1 with a bootp/dhcp address, I assume you will need to perform some kind of routing ie; default gateway, ip-helper address or static route to point to your routing device ADSL router etc try the following;
1~ configure an ip helper address on vlan 1 to point to what ever is supplying dhcp
2~ create a defualt route on the switch ie; 0.0.0.0 0.0.0.0 to next hop / routing device
3~ configure a default gateway ie; ip default-gateway x.x.x.x where x= routing device
the above can be accomplished via a serial connection to the switch using hyperterminal with the following settings
bits per second 9600
data bits 8
parity none
stop bits 1
flow control none
let me know if this resolves the issue
Mar 13, 2009 | HP ProCurve 2524 24x10/100 Mbps Networking...
Baking pizza
Are you using an 8-Port Ethernet switch to cook your pizza? Because the product description says you are.....
Anyway, if it's a frozen pizza, typical time and temps are 400F for 12 minutes or 450F for 8-10 minutes. If it's a made-grom-scratch pizza, then do 475F for 7-10 minutes. Convection only, never grill or microwave a pizza. Go until cheese is bubbly and golden brown.
Please mark as solved.
Aug 02, 2008 | IFS EtherNav D7600 8-Port Ethernet Switch...
IFS EtherNav D7600 8-Port Ethernet Switch (D7600-VV-S) Logo
377 people viewed this question
Top IFS Computers & Internet Experts
David Payne
David Payne
Are you an IFS Computer and Internet Expert? Answer questions, earn points and help others
