Question about D-Link (DI-784) Wireless Router
Ipad connects to D-Link DI-524, authenticates and drops the connection 1 second later. How do fix it so that the connection remains up?
    Problem Solver:
  • 22 Answers
I think the problem is that your router has a firewall that your iPad can't get through.
You could try going to D-Link's web site and find directions to allow your iPad to access the internet.
=) hope this helps
Posted on Jul 10, 2010
How i connect dlink access point in apple ipad
in your apple ipad switch on your wireless and search for the available networks you can find your router name just click that it will ask for the wep key its nothing but your wireless password you need to enter that then it will connect automatically
Jul 26, 2010 | D-Link AirPlus DI-524 Wireless Router
I want to put a password on my D1-524 router
then you need to login on your router. connect to it with the routers ip address and login with usr: admin and pwd admin, then go to system and change password.
Oct 12, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 does not maintain connection
Some ISPs are cutting connection after a set period of idle time to conserve users per router ratio. There are programs to "keep alive" connections (some router have this ability built-in also).
Feb 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless Cood
You can put in your wireless code by connecting to the DI-524 using the LAN cable. Open you web browser (Internet Explorer) on your computer, and type in the address http://192.168.0.1 This should take you to the sign on screen for your DI-524. user ID will be "admin" and password is blank unless you have changed it. Go to the "Wireless" button on the left. There you can specify the type of wireless security you want and the secret code. The most simple security is WEP, with 64bit WEP encryption, and "Open System" authentication. Enter a 10 digit numeric code in "Key 1". You don't need to fill our the other keys. NOTE the number down for future reference.
Jan 09, 2009 | D-Link AirPlus DI-524 Wireless Router
My D-link DI-524 Wireless router not working.
g´day m8,
Your D-Link AirPlus G DI-524 Wireless Router needs a hard reset.
Log in to your router, go to -> administration -> factory default -> Restore Factory Defaults: =  "yes"
Then save settings.
You have now reset the router.
First thing you do is set your wireless setup in your computer to the same, i.e. no security.
Test if there is connection, if, the start with the setup from the top, beginning with admin password.
/Teis
Dec 19, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Securing my wireless connection
Hi ladynb,
Open the DI-524 window by typing 192.168.0.1 into internet explorer address bar, and press enter.  Fill in your password, and press enter.  Click on the  Wireless button. This should open the Wireless Settings window for the 524.  Set SSID broadcast to  Enabled. Set Security to WEP.  Set Authentication to open system.  Set WEP Encryption to 64bit.   Set Type to HEX. Click and select radio button next to KEY1.  Enter a 10 digit number that you can remember, like 1234567890, or 1111122222.   Now click the Apply button at bottom of the screen.
Now any device that you wish to link  will will need to use this Key.   Scan for the router, connect and use Infrastructure mode, Type in the 10 digit number you were suppose to remember, and off you go.
Oct 09, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link (DI-784) Wireless Router Logo
819 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
