Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
No drive, have to push the sweeper - Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
These machines don't have power drive. You may find it harder to push when the brushes aren't turning but there is no drive on this vacuum.
Posted on Jul 10, 2010
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
Vacuum wont spin when on carpet but will spin if tilted off the carpet
Remove the bottom plate of the sweeper. Remove the sweeper brush roller and clean the end bearings of debris. Oil the bearings lightly with 3-1 oil or similar machine oil. Clean the motor shaft with alcohol as well as the brush drive area, and the inside of the drive belt. Test on a carpet for improvement--if still stopping, replace the rubber drive belt. Hope this helps!
Nov 21, 2010 | Bissell 3920 Bagless Upright Vacuum
I have to push the sweeper, there is no drive
Be sure your belt isn't slipping on the beater bar. Might be time to get a new belt or at least take off the beater bar and clean everything. Dust can cause it to slip
Jul 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to change belt on Dirt Devil Model 2003 can vac sweeper
I found out that the Royal Mfg. Co. used the same schematic from this model to make newer models which had a belt, however, this older model that I have does not have a belt drive.
Jun 14, 2009 | Vacuums
Sweeper vibrates when pushed forward.
do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Sep 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Fantom Sweeper Belt problem
Maybe it's stretched and is slipping causing friction and heat.
Try a new belt.
Mar 28, 2008 | Vacuums
Dirt Devil M084600 Dynamite
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Feb 25, 2008 | Dirt Devil M084600 Dynamite Bagless...
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Can my sweeper be repaired economically?
If you want to try yourself the part is:  67.jpg Genuine Hoover vacuum cleaner motor
Part # 43576102
Dimension Power Drive
Fits Models: U6311-930, U6317-930, U6323-930, U6329-930.
 I believe that you can repair it if you have the patience and basic understanding on how it works.
Oct 29, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
78 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
