Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
First time install software
What is Enter the WPA-PSK passphrase, where do i find this or what is it?
  • 108 Answers
The passphrase is the code your wireless router is configured with. If you do not have one you need to consult the wireless router documentation.
You may be able to use the wireless network without any security such as wpa or wep - but that means anyone could get access to your wireless network.
Posted on Apr 19, 2008
How do you write an ASCII network encryption key?
Hello. Wireless security strength depends on the mode of encryption you are going to use (WEP, WPA-PSK [TKIP], WPA2-PSK [AES], WPA-PSK [TKIP] + WPA2-PSK [AES]).
WPA-PSK should be enough to secure your Wireless network.
ASCII - Choose from any key available on the keyboardHexadecimal - Characters ( 0~9 and A~F)
  • Before setting up wireless security on the router, make sure the computer you are going to use to setup wireless security is directly connected to the router using an Ethernet cable(wired).
  • To setup wireless security on the router, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
  • Enter admin for the router user name and your password (or the default, password).
  • Choose Wireless Settings from the Menu on the left.
  • Select WPA-PSK under Security Options. Input the Passphrase.
Passphrase can be 8~63 Hexadecimal characters or 8~63 ASCII characters.
Take note of the passphrase then click Apply.
Hope this helps. Have a nice day.
Nov 24, 2011 | NetGear Computers & Internet
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
How to set a security cod for wifi
This is a Quick and easy fix!
  1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Dec 12, 2010 | NetGear WGR614 Wireless Router
I want to set up a secure netgear wireless connection
THIS IS A SUPER QUICK AND EASY FIX!
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  4. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  5. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
  6. Click Apply to save the settings
Dec 11, 2010 | NetGear WGR614 Wireless Router
How to secure my wireless router
Step 1: Open a web browser and type the IP address of the WBR series router into the address bar (default is http://192.168.0.1).
Step 2: The default username is admin (all lower case) and the default password is blank (nothing). Click on OK.
Step 3: Click on the Setup tab at the top and then click on Wireless Settings on the left-hand side.
Step 4: Select the type of WPA encryption you would like to use with your wireless adapter from the Security Mode drop down menu. For WPA-PSK select Enable WPA- Personal Wireless Security (enhanced).
Note: All wireless products on the wireless network must have the same level of security to connect to the network.
Step 5: In the WPA Personal section, configure the following:
  • Select the Cipher Type
  • Select the PSK or EAP
  • Enter your Passphrase
  • Re-Enter your Passphrase
Step 6: Click the Save Settings button to save your settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | D-Link Computers & Internet
How do I set up secured network
Nov 18, 2010 | D-Link DIR-615 Wireless Router
How can i lock my router
1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the linksys router.
3. When prompted for a Username and Password, enter the default username and password , unless you have already changed it.
4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Under SSID Name, Give a Unique name for Wireless N/w
5. Under Security Options, select WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
6. Under Security Encryption (WPA-PSK) > Passphrase, enter a passphrase.
7. * The passphrase may either be a string of 64 hexidecimal digits, or word/phrase of 8-63 ASCII characters.
* SAVE or KEEP NOTE of the passphrase - it will be required to connect wirelessly to your network.
8. Click Apply to save your settings.
9. Scan and Connect to your Wireless N/w on your Wireless Computer with your Password
Oct 02, 2010 | Linksys WRT300N Wireless Router
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Enable WPA-PSK
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click Wireless on the left hand side. Step 4 Select WPA-PSK using the radio buttons. Step 5 Enter a key (passphrase). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients. Step 6 Click on the Apply button then click on the Continue button to save your settings. Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Enable WPA-PSK
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
130 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
