Question about LG WM-2277HW Front Load Washer
Trouble Code Washer screen has an upside down F and E. Manual says unplug and call for service. What causes this code?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error FE is an overflow error which indicates that the water is overflowing i.e. the water level frequency is over 213. To start with you’ll need to check the water inlet valve assembly and replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
Code F11 on Kenmore Model No 110.45872 400
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
Your tech sheet and all the info on diagnostics is located behind the kick platethemobilian_1233.jpg
Use the tech sheet for your washer and use this service manual to see where and how to do repairs:
Duet service manual and MORE
Feb 02, 2011 | Kenmore Washing Machines
My washer is blinking upside down F and E. Manual
It is actually a TE and should be the thermistor Part#
1268202
May 08, 2010 | LG WM227HW Front Load Stackable Washing...
Error code looks like an upside down FE
The upside down F is actually a lower case t. The fault code indicates a faulty thermistor.(temperature sensor) The first step in troubleshooting is to unplug the unit for 10 sec. plug in turn on and select rinse/spin mode and no spin option to drain the water.If this does not solve the problem you will be directed to a service company.
Apr 24, 2010 | LG WM-2277HW Front Load Washer
Just flashes the code
Thermistor is out of order. Printable service MANUAL
Mar 01, 2010 | LG WM0642H
My LG WM-2277HW front load washer has an error code of upside down "F" and E. Will not run at all. Manual says to call service.
This is a water overfill condition and many things can be causing the issue.
Leaking water valve.
Plugged water lvl. switch hose.
Problem with the main computer.
A service call may be needed.
Jan 18, 2010 | LG WM-2277HW Front Load Washer
We have an LG Tromm WM2487HWM that has an upside down f and e error code. The machine will sometimes start and then quit after about a minute into the run. Unplugging and replugging in does not seem to...
We have the same problem on our washer - same model as yours. Home Depot has the warranty on this thank goodness we bought it. They replaced the motor and water pump - didn't fix the problem longer than a month. A new repairman has come out and says we need a new heater and thermistor (whatever that is - I checked - not a thermostat but possibly related??) Approx a $300 fix. Good luck.
Jun 20, 2009 | LG Washing Machines
Washer wont start
ok look in the phone book for some distributers like appliance giant or something and ask to talk to a tech they should either have there own or have numbers on file to call.
May 27, 2009 | LG WM-2277HW Front Load Washer
I have an error code it looks like an upside down F and E
on the back of the stator...the inside of the motor the part that has the whindings.plastic overload replace it..if you need help i will talk you through..also look for water or a drip ...onthejob
Dec 31, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
351 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
