Question about Maytag MSD2756GES Side by Side Refrigerator
Replacing the Adaptive Defrost Control Board
I have the part but can't find it in the feeezer. I have pulled out several panels in the back of the freezer, but have been unable to locate it. I have the new part and just need to remove the old (if I can find it) and insert the new one.
  • 1 more comment
  • Knoxy1 Apr 24, 2008
    Thanks, found it.
  • luckeecharms Jun 07, 2008
    I am trying to get the cover to slide forward so it can drop down but it will not slide. I am pulling on the two finger holds in the back but there are two tabs that won't let it budge. What is the secret?
    Susan
  • swamishreeji Sep 03, 2008
    Frost in ice campartment near outlet for despenser & ice crusher blade. It's not Defrost itself.
    Genius:
  • 1,073 Answers
It is in the control panel in the fresh food section where the cold control is located
Posted on Apr 19, 2008
  • daniel daoud Oct 10, 2011
    How did you find this board that apparently no one can get to? I took apart most of the temperature control section and cant locate this infamous board. Please advise.
Where are the refrigerator fuses located for a Maytag msd2652keb
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are no fuses in refrigerators. Individual component failure acts a fuse.
You are locked into defrost.
PART NUMBER: 67004704 - Cost: $116.00
This is located in the upper right inside your control box.
This replacement adaptive defrost control board (part number 67004704) fits several models of side-by-side refrigerators. The adaptive defrost control board starts and stops defrost cycles as the temperature of the evaporator rises and falls instead of on a set schedule.
Shut off the circuit breaker for the refrigerator before beginning this repair. Also make sure you're well grounded (Rub hands on bare metal), because electronic components can be damaged by discharges of static electricity. The board installs behind the digital display in the control panel. Procedures for removing the existing adaptive defrost control board and installing the new one vary among models.
Dec 07, 2014 | Maytag Refrigerators
Where is a Kenmore refridgerator adaptive defrost control board located
You might check in back where the compressor compartment is located. I found one for a side by side refrigerator there when we were looking for that board. It will be a circuit board and they can get pricey.
Sep 22, 2014 | Kenmore Refrigerators
Freezer is cooling high not defrosting but refirgerator is not working why please help me urgently. with best regards, gyan prakash gyandubai2010@gmail.com 00971501629102
Most Likely part 23 listed in this photo=> FRS26R4AB0 Control Panel Component's Click Here=>
240554502 Adaptive Defrost Control Board
The next most likely is=> 5303918255 Defrost Heater and Video
Look for any signs of the adaptive defrost board having burn marks, not always show burn marks on back or front but if appears to look OK Try the vidieo tutorial in link below. Best return policy I have seen. Here=> 240554502 Defrost Control Board Kit
If you have other questions please ask and rate this solution, Thanks, Sea Breeze
Mar 12, 2011 | Frigidaire FRS26R4A Side by Side...
The cooling coils are icing up. Have checked the defrost element with ohm meter it seems to be good. thermostat looks to be intact and sealed. Does this mean that I have a defrost control problem?
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Aug 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
The freezer and refrigerator temp is becoming warmer.
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Apr 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
SubZero 550 Refrigerator Coils Freezing
donna, the model posted probably has a adaptive defrost board. You definitely have a defrost problem. I hate changing these out. They can be a challenge. It's located on the right side in back on the refer controls. You have to remove the control panel. There are 2 slots in back where you can get a finger in. Pull down on these tabs and pull out at the same time. The control panel housing will pull off. This can be a real bear to do as I always fight with them. Next you would remove the light fixture screw on the right side. A little farther back will be another screw holding the right side of the upper panel. Then there will be one on the back wall next to the filter holding the upper panel there. Now the right side of the upper panel will drop down enough to get at the adaptive defrost board. You should do a test on it by shorting between L1 and test that are marked on the board. When you do this the refer will go into defrost for approx 23 minutes. If you short between the 2 and it jumps right back out of defrost, then you can assume the board is bad. I really believe that this is your problem as I have had many of them in the past. The heater and bi-metal on the evaporator usually never fail. But to be sure, you can do the test I described above. Now some models do have a mechanical defrost timer, but on the msd2758gew it should be adaptive. You can get an idea of how this board looks by going to repairclinic.com, entering your model number and following the links to get the part you need. Catriver
Aug 24, 2008 | Maytag MSD2758GEW
Bottom freezer not working
Check for frost build up behind back panel. Defrost system consist of defrost timer or adaptive control board, defrost heater, defrost thermostat. check them here
Jan 23, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Coil is Freezing Up
MWKT, did the service tech replace the adaptive defrost board? By your post it sounds like a defrost problem. Check out the pic, this is the adaptive defrost board. I find that the heater and bi-metal usually don't fail on these models and the board is the culprit. Catriver..post back
Apr 01, 2007 | Maytag MSD2758GEW
Maytag Refrigerator MSD2756DE Coils are icing up
Please disconnect power from your refrigerator before attempting the following! You will likely need an adaptive defrost board for your refrigerator. The defrost thermostat and heater is only available as an assembly and can be checked while the unit is freezing by checking the resistance with a multimeter. there should be some resistance to the heater assembly but not infinite. If the resistance is high then the heater assembly will have to be replaced. Your model has an adaptive defrost board located in the upper right hand back portion of the control panel in the refrigerator side. This cover is removed by placing your fingers in the 2 indentations at the back of the cover one on the left and one on the right and pulling down and forward. Once the cover is off there are a couple of screws directly above the lights which have to be removed and a couple of hex head screws behind the number faceplate and on the back wall near the water filter. Once these are removed the whole housing will come down the board is at the far back right. It will either be a bare circuit board or a small white box. Just unplug it and replace it with a new one. This will correct 99% of the defrost problems on this line of refrigerators.
Mar 11, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756GES Side by Side Refrigerator Logo
749 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
