Question about Coleman 10' X 10' Sundome Tent 9160K101
I have a Coleman Rechrgeable Quickpump 5999-400 and the charging instructions lack the time you should charge it for after having used it a number of times and will the indicator on the charging unit tell you it is at full charge? It stays at a constant green when plugging it in but the instructions lack a lot of information as to how long to charge it, other than the initial charge before using it. If it stays on green can it be over charged? I have charged it after every use but don't know when it is at full charge. The indicator light, as I have said, stays on green forever. Thanks for any info you can provide and just a suggestion on your instructions for use...please provide all the info needed to know when the unit is fully charged or give info on how long to charge after each use on a normal useage. Most other chargers will indicate when fully charged or offer optimum charge time after each use,. Thanks.
  • 68 Answers
SOURCE: burner lights and then goes out almost immediately
http://www.coleman.com/coleman/images/pdf/2300-700.pdf
Trouble shooting guide
Posted on Mar 25, 2009
drolllord
  • 9 Answers
SOURCE: Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Posted on Jun 19, 2009
SOURCE: Dead battery?
The battery is a commonly available 6 volt 4.5 ah sealed lead battery. Interstate has them and many other suppliers. I think same battery used some security systems...
Posted on Aug 18, 2009
  • 5 Answers
SOURCE: my colman is at full charge and when i plug the
Mine had exactly the same problem. unscrew the filter from the bottom of the pump and using a nail or long screw spin the impeller which in mine was jammed due to calcuim buildup etc. Then clean as per the booklet clr etc
Posted on Sep 14, 2009
SOURCE: coleman hot water on demand
Does anyone have a AC charger for the Hot Water Heater on Demand? I would be willing to buy one.
Thanks,
llhancock
Posted on Mar 16, 2010
Charge Time for 5312 Lantern Battery?
Charge time is 18hrs. If you left it on and it was flat, imediately charge for 40hrs.
heres the manual.
http://r1.coleman.com/Manuals/5312R.pdf
Feb 12, 2014 | Coleman Retro Rechargeable Battery Powered...
Is my old Coleman QuickPump 5999-200C compatable with new Quickbeds?
If the new bed has a built in pump, you won't need the old pump. If not then you can use your pump on the new bed. It all depends on the model you choose to replace your old one.
Aug 05, 2012 | Coleman Quickpump
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Coleman rechargeable Quickpump has stopped working. It was dropped and the black wire broke off of the charging receptacle in the back. When I opened it and touched the black to the terminal it did...
I bought this about a year ago and used it once. Took it out today and it did not work after I charged it all day today. Not sure why or how to fix the problem.
Dec 31, 2009 | Coleman Quickpump
Will not keep a charge
How long have you used this bluetooth device?...For if this is already a yera or more, then probably the its rechrgeable battery is already worn out and must be replaced. If not you need to dheck its mounting if it somewhat loose or damage.
Jul 24, 2009 | Just Wireless Bluetooth Headset Wireless...
Coleman powermate 1850 charge time
i advice you not to keep it plugged in too long...just about enough to get it workin....
:had a bad over-charge axcident..
Jul 16, 2009 | Electrical Supplies
How to use the tire pump tool on the quickpump.
I have the instructions if you send me your e-mail address i will send them to you.
Jul 10, 2009 | Air Tools & Compressors
Air pump stops blowing air after a few seconds.
Check for good spring tension on the battery connections and make sure the switch isn't coming apart. I had the same problem with 2 different pumps and they both had both issues.
Mar 22, 2009 | Coleman Quickpump
Coleman 10' X 10' Sundome Tent 9160K101 Logo
362 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
