Question about Samsung RB195ABBP (187 cu ft) Bottom Freezer French Door Refrigerator
Noises and over freezing - Samsung RB195ABBP refrigerator
Long story. All I needed was the doors switched, but the people doing it didn't have the right parts, so both the upper door and freezer bottom were hung incorrectly, causing the motors to run and run. The upper door is OK for now (doors still backwards as we wait for the right parts) and I have the lower door propped up with a doorstop until it can be addressed. BUT, meantime it has developed two different noises and a problem: 1 Clicking sound on and off frequently. ( clue? I do not have it hooked up for ice) 2 Descending groaning sound now and then, sometimes connected to the clicking sound. And, 3 it freezes things to a rock, even on the highest temperature (8 degrees) . The people who come out don't seem to know squat. HELP!!!!
Sorry if this is repeated --difficulties signing in.
  • 4,793 Answers
Unless the doors fit perfectly you will have a real problem.so, youve tried the cowboys,now try the indians.....seriously, only pay for a service that has been carried out to your satisfaction,or get someone who can do the job YOU are paying for.
all my collegues do the job, then get paid.
Posted on Jul 10, 2010
Samsung RS26DDAPN1 freezing the fridge area, damper doesnt work. I changed de main motherboard, the damper and sensor temperture and still doing the same. I run the diagnostic mode and nothing...
make sure the door light switches are being pressed correctly with the doors closed. I have seen these model have the circulating fan stop working allowing cold air to settle on the lower shelves freezing the food. Cold air will sink to the bottom because it is heavier than warm air Appliance 911 Sea Breeze
Jul 15, 2016 | Samsung Refrigerators
The refrigerator is not cooling
Do you find that the freezer section is freezing up more too.
If you place you hand at the top of the fridge you should feel the cold air blowing through and also hear the fan kicking in to chill with door open. If freezer section is freezing up open freezer door press the door switch in and hold it in. you should hear the fan kick in. If not it could be frozen and all the channel too . you can take back panel off and remove the ice or switch it off and defrost it . Try this and let me know out come.
Jeff
Jun 10, 2014 | Samsung RS265TD
Samsung side by side twin cool Refrigerator side not cooling
Is it freezing from the bottom up? If so check the drain is clear. If it's freezing all over, check the condenser is clean and clear and the compressor switches off when it reaches temperature. Lastly, check the door seals properly all the way round
Apr 23, 2012 | Samsung Refrigerators
Both of our light bulbs on top burned out the same time/day. Model # GLRT218WD My husband changed one light bulb and it didn't work. Does that whole piece come out of the top, where the light bulbs...
Check the door switch. Alot of the time when the freezer door stays open it creates condensation and than when you close the door is can freeze the door switch closed so the switch thinks that the door is always closed. If you need further assistance or this does not cure your problem please reply.
Aug 01, 2011 | Frigidaire Gallery GLRT218WD Stainless...
My top mount refrigerator is freezing food in the vegetable bins and on the door
This is normally the result of poor air flow movement in the refrigerator but it could also be a control board or sensor problem. There are a couple of things you can try first before replacing any parts. There is a small supply air vent for the bottom meat bin in the bottom of the refrigerator, close this vent off. You can also adjust the controls, set the refrigerator control to a warmer setting usually almost to the warmest and the freezer control to a slightly colder setting. This will keep the unit running longer allowing more air movement. This will usually help solve this problem.
Feb 11, 2011 | Samsung RB195ABBP (187 cu ft) Bottom...
Freezer fan quit working after ice took over (kids kept leaving freezer door open) we defrosted and the temp will not drop below 40 degrees is there a reset to restart the fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No,
Probably wrecked the fan motor...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung RB195ABBP (187 cu ft) Bottom Freezer French Door Refrigerator Logo
153 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
