Question about Malber P21 Front Load Washer
Cracked detergent dispenser
I want to replace the cracked dispenser....where do I buy one?
    Novelist:
  • 160 Answers
Call a appliance parts dealer. In the phone book its under appliance parts. Make sure you have the model number which is inside the door before you call.
Posted on Jul 10, 2010
How to place spring back in place defined detergent dispenser
Thank you for your inquiry, friend!
Based off the information you have provided the spring on your Frigidaire washer came off in your hand and you would like to replace it. Typically, if the spring has come out of the dispenser you may need to replace the whole dispenser. I would recommend pulling out the drawer to see if any parts have been become cracked or broken. In order to purchase the correct parts you should contact the manufacturer. I hope this helps. -Matt
Oct 11, 2014 | Electrolux Washing Machines
My Neptune MAH3 is leaking from the detergent dispenser.
The detergent dispenser is easily replaced, simply held in place by the four corner screws which fasten the door and door frame to the washing machine.
Unless the dispenser itself is cracked, your leak may actually be occurring from a loose clamp or hose attached to the dispenser. Or perhaps the leak is coming from the hoses, which are connected to the back of the machine in the same corner as the dispenser. The fill valve, to which the hoses are connected, could also be the problem. These valves are made of plastic, and can eventually crack and fail. This valve is also fairly easy to replace.
If it's been awhile since your washing machine hoses were installed, I would highly recommend changing them out if/when you repair other items. Stainless steel hoses are now available, preferable to plain rubber ones, better to handle constant water pressure. Be sure to note a date on the back of your machine with a Sharpie or paint pen the date the hoses, fill valve, or other items were changed. I do this as a reminder for the fill valve, which gets eaten up by our municipal water supply about every four years.
Aug 16, 2014 | Maytag Neptune MAH5500B Front Load Washer
Detergent dispenser doesn't open
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
Apr 22, 2014 | Indesit Dishwashers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Need help on repair or stop leak from the detergent container
new unit then call for sears warranty, other wise, if you use powder detergent it could be built up if it coming out front.. remove drwr by pressing tab at rear and pulling out. cracked drwr? accumulation in disp asm? or crack in disp asm/housing. approx $100 for dispenser asm. (not drawer)
Mar 15, 2009 | Kenmore Elite 45986 Front Load Washer
Fab. softener dispenser will not empty
I had this exact problem, with the exact same washer (but the Kenmore version), and it was solved by replacing (Not sure the exact name of the part) but its the plastic Detergent Dispenser housing, that you can see when u remove the Detergent Dispenser draw. There was a crack in mine,,, and the softner would either fully, or dispense half into the first rinse cycle.
Mar 13, 2009 | Frigidaire GLTF2940ES Front Load Washer
I have a DW12-PFE2-2 the dishwasher tablet does not dissolve,it is still in the dishwasher detergent dispenser after wash has finished?
HI Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
THANK U,,,,,,,,,,,,,,,,,,
Sep 12, 2008 | Haier Dishwashers
Malber P21 Front Load Washer Logo
55 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
