Question about RCA HD52W59 HDTV Projection Television
My RCA HDTV shut off on its own and after several attempts to turn it on it just goes on for a second then shuts itself off again. Help please.
  • RCA Master
  • 8,617 Answers
Replace the deflection board. You can get a replacement deflection board at www.tvrepairworld.com
Posted on Jul 10, 2010
RCA 50: HDTV, just started shutting itself off and won't come back on for several minutes or over an hour what could cause this
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
Sep 16, 2012 | RCA Televison & Video
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
Screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Feb 02, 2009 | RCA HD52W59 HDTV Projection Television
Rca d52w19b turns off after being turned on
does it continue to turn off then on by itself? Does the led flash if you try to power it back on again when it shuts off. If so how many times does it blink? Please respond to this same post when responding.
Jul 06, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Shuts off
Reedasaurus resolder your flyback.
Neednonrcatv, you need a new flyback you can get one at the following link with free tech support so you can install it yourself, very easy repair you need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Apr 22, 2008 | RCA Scenium D40W20 40" Rear Projection...
Please someone help me with my tv
ok i see alot of these at the shop( i have one in front of me right now) The rca itc22 chasis is bad about this.. If the processor finds any problems it will shut it down. THe big problem it can be one of about 20 different things. As the customer the first thing you can do is unplug the set and leave it of 30 min to an hour. then try it again. ( I have yet to see this work) There are some basic assumptions that you can make.. if you see the light flash then it wont be a fuse. the processor is getting power. This is where a technicain starts his troubleshooting. You said it would shut itself down every once in awile... could be a bad connection or a component that finally overheated then failed. The processor on this set records errors so a technician can read these with special computer interface equipment. repairs on the set generally run 150 to 500. These sets are about 800 new at walmart so you have to make the decision to repair
Mar 04, 2008 | Televison & Video
Sound Fades, then TV shuts off then continues to recycle on & off
Sometims several capacitors start going bad giving you the audio problem, but I don't remember the set turning itself off. That could be a secondary problem around the flyback transformer which may have a bad solder connection. I would check that first. Otherwise, I would be tempted to go with HDTV.
May 29, 2007 | RCA F36685 36" TV
RCA HD52W59 HDTV Projection Television Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
