I use HP Deskjet F4400, after I replaced the black-ink cartridge I failed to print or copy.I was told that I have to take out the cartridge and shake and clean the inkjethead. However I don,t know how to clean the haed. Teach me how to clean the inkjet head. Thank you.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the cartridges and visually inspect). Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
  • tyamaki Jul 12, 2010
    I replaced both tricolor and black cartridge with new one. I tried everything you told me to do. But it did not solve the problem and orange dot on the front upper left side still blinks. Any other suggestion at this point ? Mr.RyleeSmith.
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Can you remove the battery from an hp F4480 printer to make it ignore incompatible cartridge message
Unfortunately, this does not work.
With respect to the HP 60 cartridge error message ("Incompatible Print Cartridges") and inability to print with your HP Deskjet F4480 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (which is typical of the 'incompatible error' alert). These same failures can (and randomly do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to A. and B), this will identify which ink cartridge is causing the issue:
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
            NOTE: To our team's knowledge there is no 'cartridge error bypass' method available for the HP Deskjet printer model. The cartridge will mostly likely need to be replaced with a new one.
            Please note that we provide professional ink cartridge refilling services in multiple countries:
            Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
            Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
            Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
            Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
            Fry's Electronics USA Ink Refill Service (34 stores): http://www.frys.com/ads/page51
            Best Buy Canada (4 stores) Refill Service: Downsview, Sherway, Toronto, & Vancouver (additional Toronto Best Buy stores opening in Fall 2014).
            Micro Center USA Refill Service (8+ stores): http://www.microcenter.com/site/content/refill-service.aspx
            We also have ink refilling centers in many University bookstores across the USA & Canada:
            Brigham Young University, Brigham Young University Bookstore - Idaho (BYU-I),
            Cornell University (CU), Kansas University (KU), New York University (NYU), San Diego State University (SDSU), University of San Diego (USD), University of Wisconsin - Madison,
            University of Virginia (UVA): http://www.cavaliercomputers.com/inkjetrefill.asp?
            Queens University (Kingston, Ontario, Canada) & University of Calgary (Calgary, Alberta, Canada)
            Refill Store Map Locator: http://www.go2ris.com/#findstore
            Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
            -Thank you
Jun 02, 2014 | HP F4480 All-In-One Printer
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
My HP Deskjet D4260 printer has been unused for 2 years. I have been told it would be useless to replace dried cartridges, because the inkjets themselves are probably clogged, and therefore the printer is...
That is absolutely not true. The printer you have uses integrated print head cartridges. This means every time you replace the ink cartridges you are replacing the print heads. Throw out the dried up ink cartridges and buy new ones. Your printer takes the HP 74 black and HP 75 color cartridges. There are XL versions of these cartridges that hold more ink and are a better value.
Dec 19, 2009 | HP Deskjet D4260 Printer
New HP printer Deskjet F4180 will not print
Hey
Try to take the cartridges out and clean the cartridges and cartridge holder with damp clothe
now shake the cartrdges and clean it agaian with damp cloth
put the cartridges back in and see if it works
Sep 18, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
480 people viewed this question
k24674
