Question about InFocus IN24 Multimedia Projector
I have a new bulb but am getting a dark shadow around the edges of the picture. The bulb seems fine, but the shadowing is covering about half the screen. Any ideas?
  • saleever Jul 10, 2010
    What glue would be used. I have some time and maybe can find the patience.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
The light tunnel under the colorwheel has collasped. This is a major repair. I have known some to glue the tunnel back together, but it requires patience and skill and the right kind of glue....
Posted on Jul 10, 2010
Testimonial: "Quick response. Seems to be correct."
  • patrick reagan Jul 10, 2010
    the glue i've seen used time after time is LOCTITE 444. I also recomend the spray accelerator to go use for super fast drying.
My unit seems to work fine, except there is a dark shadow covering the right third of the projected image. Is this a sign that the bulb is going out?
this is the light tunnel needing to be adjusted or replaced because is has collasped due to the heat given off by the lamp during the life of the projector.
Aug 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have a very dark vertical shadow over half the screen. Rest is fine. Settings fine bulb hours only 609
the light tunnel is collapsing and needs to be replaced. you can get the part from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 20, 2009 | InFocus ScreenPlay 4805 Multimedia...
I have a 46 Toshiba DLP television
Hi,it does sound like it could be that mirror since thats what direct the light of the lamp.You will need to replace the light tunnel.
Oct 05, 2009 | Toshiba Televison & Video
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Dark shadow like mark on screen
The drak Shadow mark I see on my Screen looks like the black soot like marks you see at the end of a flourescent tube. I think it is the back light.
Dec 18, 2008 | Philips 32PF5531D 32 in. LCD Television
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Print quality
Change the PCU cartridge.
Mar 01, 2008 | HP LaserJet 1020 Printer
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
InFocus IN24 Multimedia Projector Logo
512 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
