Question about Samsung HLM617W 61" Rear Projection Television
I have replaced the color wheel on my samsung hlm617w and stupidly did not keep acurate track of where all the wires I disconnected plug back in. I have looked in vain on the internet to find a diagram. Can you help me with this or direct me where I can get a diagram?
  • Shahid Electronics
    Shahid Electronics Jul 10, 2010
    Did you got helpful info in chat session?
  • 1,476 Answers
You can get the service manual for this unit at http://www.servicemanuals.net for $17.00 as a download. It would have all the information you would need to hook up your unit and would be useful in the future if you have additional problems.
Apparently you did not read my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine in which I state "Before disconnecting any cables mark them for easy reassembly." At least you should be able to accomplish your goal of getting your unit back together with the service manual.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 10, 2010
  • Kim Yearick
    Kim Yearick Jul 10, 2010
    Glad I could be of help. Thanks for the good rating!!!
    hardrocko
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
What does the color wheel "plug in" to?
the white clip that the 2 white/1 blue wire plugs into breaks when you remove the the wire. This should not be a problem as the wire should still fit snug when you plug back in.
May 12, 2009 | Samsung DLP HL-P5663W 56" TV
How to install a color wheel on a samsung hl-p6163w
To install a color wheel on HL-P6163w just: unplug set and remove rear cover. Remove the screws holding the plastic cover over the audio/video jacks. Remove the screws holding the large metal box (digital module) in place. Disconnect the plugs on right side of the digital module and disconnect the plugs remaining in your way of removing light engine, located on the metal sheet on right side of set. Remove the two screws that hold the light engine in place and slide towards you carefully so as to not stretch any remaining wires. Black, plastic cover that shields the color wheel has three screws that hold it in place, and you need a long screwdriver to reach them(matgnetic tip if possible). Once you remove the cover you will see the color wheel and the screws holding it in place. There are two plug connectors attaching it to the shielded DMD module and make sure to put the ribbon connector back on the right way. It has contacts on one side only. Carefully reconnect all plugs and if the plugs are identical you need not worry in which order you connect them. Make sure that you plug all connectors in and engage safety switch for lamp cover to test your work. It should be fairly easy but a bit time consuming for your first round with light engine servicing. Keep your distance from the ballast that runs the lamp while testing as it can pack a powerful punch. Good luck, Russmann.
May 05, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung hlm617w tv
The color wheel is bad. Mine did the same thing, eventually the wheel shattered, pieces of glass everywhere and picture was black and white
Oct 06, 2008 | Samsung HLM617W 61" Rear Projection...
Samsung HLM617W 61" Rear Projection Television Logo
262 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
