Question about Vacuums
I have a Broan Nutone central vacuum. The power head seems to stall unless you lift up on the handle. I think I may need to change the belt but cannot find a place to purchase one to see if this is the problem Model number BN180 type 1
  • 701 Answers
You are correct, you need a new belt. You can find belts for the Broan BN180 at www.vacbelts.com.
Posted on Oct 09, 2009
  • 328 Answers
If the power head is spinning when you lift up the handle then the head could be blocked with dirt. You may need to undo the floor head to see if the entire brush roll is clear as well as the main dirt channel/turbine wheel. Ensure that everything is clear before assuming it may be the belt that needs to be replaced.
You may well have to call or contact the main company who makes Broan Nutone models for them to send out / query the power head problem.
Posted on Apr 19, 2008
Nutone CV353 does not shut off, think it is the relay board
You probably have a stuck relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Take the unit to a local vacuum repair center for service.
Jun 26, 2010 | Broan-NuTone CV353 Central Vacuum
THE HOSE IS BEGINGING TO TEAR AT THE POINT IT CONNECTS TO THE HANDLE. DO I HAVE TO BUY A NEW HOSE OR CAN THIS BE REPAIRED? IF IT CAN BE REPAIRED HOW DO i DO THIS?
if you have a power head that the power flows through the hose you should not try and repair unless you are a service centre other wise most of the time you end up buy a new hose
but if it is not to bad some people just duck tape it
Mar 03, 2010 | Broan-NuTone CV353 Central Vacuum
A Nutone CV-450 System with inlet nozzle switch issues
You are suffering a connection problem of the hose end fitting to the wall outlet. Either the hose is not aligned with the two pins in the wall outlet, or the pins in the outlet are dirty and not making good connection to the hose end fittting.
Jan 01, 2010 | Broan-NuTone CV450 Central Bagged Central...
NuTone central vacuum won't shut off
http://www.centralvacuumstores.com/cvs/trouble_help.php#runs_continuously
Here is a link to help you find a local dealer:
http://dealer.nutone.com/DealerLocator.aspx?unit_id=002&cata_id=8
Dec 30, 2009 | Broan-NuTone CV353 Central Vacuum
Beater brush won't spin when on carpet
You need to change the belt. When it does that it means it is worn. You can get replacement belts for it here:
Central Vacuum Belts
or here is
Broan Central Vacuum Belts
Nov 04, 2009 | Broan-NuTone CV350 Performance Bagged...
Motor won't shut off on central vacuum
Your relay is bad. This is very easy to change out yourself. There are several websites that sell this part online. Some websites offer free tech support.
Mar 01, 2009 | Broan-NuTone CV350 Performance Bagged...
NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
I have a broan central vac system need belt for cv315-b vac head cant seem to find one any idea where i can get 1 thanks
I believe that the Broan replacement part number for the belt for the CV-315 power head is a 9967-0585. available through a Broan/Nutone dealer.
May 11, 2008 | Vacuums
Vacuums Logo
318 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
