Question about Microwave Ovens
GE Microwave w/convection and grill Model JES1290 ML-01. Put popcorn into MW, set Popcorn Button. Approximately 1 minute, rumbling began and fire shot out from right side of interior. Immediately turned off, reset and tried again with same results. Bought February 23, 2007. What is likely problem? Will warranty cover?
  • 1 more comment
  • Anonymous Jan 13, 2009
    Have the same problem with the same model JES1290SK. The unit started throwing sparks on defrost and just today started on fire using the popcorn function.
    Is there any recall on this product as it is thoroughly UNSAFE?
    J. Sans
  • sansbw Jan 13, 2009
    Have the same problem on the GE JES1290SK. Started throwing sparks
    often after 14 months of use during defrost use. Now started on fire
    during popcorn mode.
    Product is thoroughly unsafe and GE engineers should be prosecuted for distributing this junk.
    Is there any product recall or consumer fix for this? Please let me know.
    Sansbw
  • Anonymous May 15, 2009
    On the phone with father , who has the same problem with the GE JES1290SK-01 model. I was trying to see if there was a recall on this product also. I let him know I found other people with the same problem.
    He states it throws sparks out of the right side of the unit while in use so he quit using it.
We have found the problem to be the magnetron, an expensive part.
Posted on Sep 03, 2012
Mine shot out flames too. worked finr for 4 months and now no heat in micro mode. looking into disassemble.
Posted on Oct 03, 2011
    Genius:
  • 1,673 Answers
I would not use the oven like that! Take it in for service to at least know what happened. If it is under warranty this normaly should be at no cost. Some component probabably failed badly!
Jerry G.
Posted on Apr 19, 2008
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
I have the same problem, and plastic cover is scorched w/ hole
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 15, 2009 | GE JES1290 Convection/Microwave Oven
Bright flash inside microwave
try a different brand of popcorn & let me no what happens
May 12, 2008 | GE JES1290 Convection/Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Will not pop popcorn without burning it
use Orville Rickenbacker ah you know who lol set it for five minutes when you hear it slow take it out works for me no the oven don't need repair popcorn's tough the best way i know to make popcorn is an electric skillet yum yum
Feb 16, 2008 | GE JEM31 Microwave Oven
Popcorn
Some microwaves specially if convection type you will need to get a microwave safe bowl turn upsidedown and place the popcorn on top of the bowl for it to pop properly.
Feb 14, 2008 | Viking VMOC205SS Microwave Oven
Microwave Ovens Logo
332 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
