Cant find the wireless card utility to search for wireless networks
  • Computers & ... Master
  • 2,263 Answers
What is the operating system on your computer ?
If it is windows XP then you can enable the wireless zero configuration and use windows wireless connection manager.
For windows Vista and 7 the wireless utility is built in and you can use the Windoes.
Click Here for more information about the routers and network
Posted on Jul 10, 2010
Dell NetworkDell Wireless 1350 WLAN MiniPC
The Dell Wireless WLAN Card Utility locates, manages and provides information about wireless networks in your area.
The Dell Wireless WLAN Card Utility allows you to create network profiles, connect to an available network, and diagnose connection problems.
Enable the utility through an icon in the notification area of your desktop, or locate it in the programs list depending on which Dell computer you have.
Turn on the Dell laptop and make sure the wireless switch is in the "On" position.
Right-click the utility icon in the notification area of your desktop.
The icon appears as a set of four green, yellow, red or white bars, depending on the signal strength in your area.
Click "Enable Radio."
Right-click the icon and click "Open Utility" to open the Dell Wireless WLAN Card Utility.
Control Panel
Click "Start" and select "Dell Wireless WLAN Card Utility."
Click the box next to "Enable Radio" and click "Apply."
Click "OK."
http://support.dell.com/support/edocs/network/p70008/en/utility.htm
http://support.dell.com/support/edocs/network/p70008/en/wizard.htm
Jul 05, 2013 | Dell NetworkDell Wireless 1350 WLAN...
Lost security code for 3 dongle. need it to set another computer up
ya ya ya , you blame your wife!!! don't do that again as gentleman. Well do this,:
open this link in the computer which is connected to wireless,
http://www.nirsoft.net/utils/wireless_key.html
download the program and run this utility you will find your wireless key
Jan 11, 2012 | LG ANWF100 Wireless dongle
Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Feb 25, 2009 | Netopia 2247NWG-VGx Wireless Router...
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
Belkin wireless G adapter shows as working but no networks
make sure the Wireless zero configuration or WLAN auto configuration service on your OS is running
Try to search for wireless network using the Belkin wireless utility after disabling windows
Nov 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless not working
First make sure the Wireless LAN card driver is installed. Then go to device manager and make sure the Wireless LAN card is enabled. If not, right click on the Wireless LAN card icon and select enable. Once that is done you should be able to search for wireless networks. If a wireless router is not broadcasting the SSID for the wireless network, the Wireless LAN card will not be able to locate the network during the search. If that is the case, you will need to set up the connection manually. If you can see the correct wireless network during the search but still can't connect to the network, it may not be an open network, so make sure you have the correct security settings for the network you want to connect to. If you did not set up the wireless network, you will need to get the security information from the network administrator.
Jun 10, 2008 | Everex StepNote NC1500 Notebook
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
My wireless card is Dell TrueMobile 1150 Series Wireless LAN Mini PCI Card.when i connect my laptop that i ve already added to my wireless network (workgroup),it keep telling me that wireless connection...
Hi, Sometimes the built-in Windows Wireless Configuration Utility fouls up. You may have to install and use the Client Manager Application for the TrueMobile 1150 Wireless Network Card. This is better explained at Hope this be of some help/idea. Pls post back how things turn up or should you need further information. Good luck and kind regards.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
