Question about Autotek SX280 Car Audio Amplifier
I have a oldschool autotek 44 and i dont know what what colors go to the power the ground are the speakers
4 Suggested Answers
SOURCE: autotek mx1500.1
i am a master audio amp repairman i am working on an mean machine mx 1500.1 the RCA inputs wer just worn out on mine,
but your problem is much worse your power supply is gone, all mean machine`s are CLASS X mind you NOT CLASS D basicly all that means is that the audio feads directly into one big power supply unit instead of having both an input and output stage.I recomend you find a web site or audio shop with a phone number
for the autotek corp. and have it sent in..DO NOT WORK YOURSELF
Posted on Feb 21, 2008
  • 631 Answers
SOURCE: wire Identity
If the plug is like the BTS series amps...
Image of connector on amplifier
Posted on Apr 13, 2008
  • 21 Answers
SOURCE: Autotek Bass Thrust 44 Wiring
thin blue wire is the remote wire and goes to the deck remote line
large diam wire goes to battery
large diam "black" goes to ground
rca ... wires with the metal ends plug into the white and red holes
you have two sets of speaker wire comming off the amp also
hope this helps
Posted on Dec 26, 2008
Need a wiring diagram for a DEH-X6600BT. IT'S GOING IN A 1993 CHEVY ASTRO VAN. I KNOW KNOW THE WIRES OF THE VAN. I NEED TO KNOW WHAT TO CONNECT TO ON THE RADIO. THAY ARE DIFFERENT COLORS.
I hope someone comes along who can help; in the meantime, you might try the following. Naturally the power wires will be 12V and usually red(+) and black(-), if they're not, you can examine the other colors, to determine if their are separate ground wires for each speaker. If it uses a remote, and you want to hook that up; I can't help. sorry. But, if the speakers have a common ground, there will only be 1 wire for each speaker, the other connects to the ground of the car. If there are two wires for each speaker, they will be 4 different colors, with a 2nd wire which has the same color for all 4 speakers, so each speaker has a colored wire, and a common colored wire. This will leave the power connections, unless you have other controllers (see above).
One you know which are the power wires, you can connect them to a spare 12 V battery, and then comes the fun part. While adjusting the radio for front back, left and right, using the colored and a common wire for each speaker, this will be the same as the ground wire for the power even if not the same color, you can connect it to ground for the test. Then connect the colored wire and common wire to a speaker, by adjusting the controls you can find out if that colored wire is for front or back, left or right. Then you'll have your color code.
Although prolonged use of only one speaker or only two could cause damage to the radio, short use to troubleshoot at low volume shouldn't be an issue. Just don't use it that way.for a long time!
I hope this helps. Let me know.by rating up my answer! :-)
Sep 03, 2015 | Cars & Trucks
I have two kicker cvr dual voice coil 4 ohms to a
what about the remote power wire from the radio? 2 channel or four channel(amps)? are the speakers running parallel or in series? are you using a mono block? or an EQ?
Oct 13, 2014 | Car Audio & Video
I dont know how to hook it up
2 grey 2 green and 2 purles are speaker outputs. one of each color should have a black line. thats usually the speaker negative. blue is remote power out to connect to remote power to amp. red is 12 volt power(+). black is power ground (-) yellow is switched power from fuse block.
Mar 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
Power turns on then 1 second after protection light comes on and power light blinks
MAKE SURE THAT THE POWER AND ESPECIALLY THE GROUND CONNECTIONS ARE 100%. REMOVE THE RCA INPUTS AND SPEAKERS. POWER THE AMPLIFIER UP AGAIN UNDER THIS NO INPUT, NO SPEAKER LOAD CONDITION AND IF IT STILL GOES INTO PROTECTION, THEN IT WILL NEED TO BE SERVICED. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE.......V
Dec 10, 2009 | Autotek Car Audio & Video
STEREO SHUTS OFF BY IT SELF. IT IS AUTOTEK MM1400.1D what size fuse shoud be in it?it has two 40s in it now.
sounds like the protection circut of amp. check for solid ground and continous power from battery. Doed it get very hot?
Sep 17, 2009 | Autotek Car Audio & Video
hope this helps
Dec 11, 2008 | Car Audio & Video
Wiring colors
You will need a voltmeter. Normally red is power, black i ground, yellow is memory power. the best way to know for sure is to use a voltmeter to test what each wire is recieving in power and when. If the key is off then the wire that has 12volts dc is for memory and the main power wire should be at 0volts dc. When the key is on that wire should have power now. the ground will be black on that car. Good luck.
Feb 20, 2008 | Car Audio & Video
Autotek mx1500.1
Jan 30, 2007 | Autotek MX1500.1 Car Audio Amplifier
Autotek SX280 Car Audio Amplifier Logo
206 people viewed this question
Top Autotek Car Audio & Video Experts
Professor_V
Professor_V
Tom Chichester
FastHarley
FastHarley
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
