Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
My HLP5085W stopped working. THe tv would try to
My HLP5085W stopped working. THe tv would try to power up but it would just cycle through the LEDs (no happy face) and eventually a light bulb error. I replaced the lamp and ballast....still no change. What do I do next?
  • srosenz Jul 10, 2010
    Even when I manually hold the blue switch down it doesn;t seem to help
  • 1,476 Answers
Sounds like you may have a misplaced lamp door safety switch. I have a tip at http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which explains the problem and how to fix it. Let me know if you need more help.
Thanks for using Fixya and for the generous rating.
hardrocko
Posted on Jul 10, 2010
  • Kim Yearick
    Kim Yearick Jul 10, 2010
    By the blue switch I assume that you mean the lamp door switch? If so then use a DMM on resistance to check continuity. You should have an infinite reading first, then push the switch and you should have no resistance. If this checks out then I would look at the Low Voltage power supply for problems. Bad caps, etc. I have a tip athttp://www.fixya.com/support/r4606286-tr... which should be helpful. If you still have problems after this let me know and I will try to help.
    Thanks for using FixYa and for the generous rating!!!!!
    hardrocko
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
My AEG T37400 lavatherm standanlone tumble dryer works for a turns of the drum then stops.
Alarm conditions during operation of the dryer
The LEDs begin to flash if one of the following malfunctions occurs:
  • NTC open (the LEDs flash in sequence from right to left)
  • NTC short-circuited (the LEDs flash in sequence from right to left)
  • If the START button is pressed for more than 20 seconds while a cycle is in operation all the LEDs flash.
25679338-hf2jxxovvq5cn05mugly0fcq-5-5.jpg If the microprocessor identifies one of the conditions listed above, operation of the dryer is interrupted; the LEDs continue to flash in order to warn the user of the malfunction.
If the error is eliminated, the dryer returns to normal operation when the programme selector knob is turned to RESET and the drying cycle is re-selected.
Dado
May 04, 2015 | AEG Dryers
Blue safety switch in back of samsung tv hlp5085w is that suppose to be up or down
The back closes on it and shoves it forward. It prevents the lamp and set from working with rear cover removed.
Nov 04, 2012 | Samsung HLP5085W 50" Rear Projection...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
I try to get tv 50" Samsung HL-P5085W i want to know if this kind of tv works good
Yes. This is a good set. Picture is good. But keep in mind that Samsung no longer makes this set and stopped making DLP tv"s. Parts are dwindling.
Apr 09, 2010 | Samsung HLP5085W 50" Rear Projection...
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
Feb 24, 2009 | Dell 1720dn Laser Printer
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
