Question about Panasonic CW-XC243HU Air Conditioner
Hi have a invertor (panasonic) r410a mod - CSE28fkr. I about 2 yrs old. Has started to turn itsel*** while on heat(shuts vents) all the lights stay on and the power light flashes?? whats going on do i need a service?? Oh yeah i recently cleaned the inside filters too.
djchillsnyc
  • 152 Answers
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Posted on Dec 14, 2008
PCCCTech
SOURCE: Panasonic PT-56LCZ70 no picture or sound
My name is Jonathan and I am an employee at the Panasonic Customer Call Center. Based on the symptoms you've described, I'd recommend contacting the Panasonic Customer Call Center at 1-800-211-7262 for assistance. We are here to help customers that have purchased (or are considering purchasing) our products and would like to assist you with resolving the symptoms described here. Our hours of operation are:
Mon - Fri, 9 AM - 9 PM EST
Sat - Sun, 10 AM - 7 PM EST
Posted on Jan 22, 2009
  • 17 Answers
SOURCE: Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Posted on Sep 22, 2009
SOURCE: where is the air filter on my Panasonic PT50LCX64 TV and how can I clean it?
I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Oct 18, 2009
SOURCE: panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Posted on Nov 13, 2009
I have a Frigidaire microwave mod:# FMV156DCG. It is about 7 years old. Last week it started tuning itself off. It will run for about a min or 2 then the motor stops but the timer and light stay on. Any...
Possibly is overheating. check all of your vents to make sure that they are not blocked. I have seen some that the vent holes in back were completely covered with lint, because that is where the microwaves pulled the air into the unit to cool the magnetron. If your vents are blocked it cannot pull that air and it will cause a thermostat mounted on the magnetron to over heat and kick it off line. There is also a chance that the thermostat mentioned above is going bad as well. Hope this helps!
Mar 03, 2015 | Frigidaire FMV156DC Microwave Oven
Dryer heating element comes on sometimes and then shuts off.
Start by checking all the thermostats for continuity.
Nov 05, 2012 | Dryers
Lost manual for model R410A Daikin invertor. Where can i find a new one?
google daikin (model number) manual . what are you trying to do or just want a manual ?they really dont tell you much in them.
Nov 03, 2010 | Cfm Daikin R410a Split System Air...
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer 4 yrs young and won't heat. Drum turns.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 04, 2009 | Televison & Video
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Panasonic CW-XC243HU Air Conditioner Logo
196 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
