Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
    Novelist:
  • 160 Answers
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Posted on Jul 10, 2010
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My oven will not get hot at the bottom
If the broil and top portion of the cooktop work, then you are in need of a new baking element. If other settings don't work, your control board needs to be tested.
Aug 06, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom baking element doesn't work. The element itself is OK
Is it getting power from the board when you select bake? If not I would suspect the board, especially if all else works ok. Does everything else work?
Sep 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire wall over model number CGEB30S8AB1 is not heating. It is just the bottom bake element. I tried to replace the element but it is still not working. I can hear the relay clicking but it will...
I had this problem a year ago (both elements worked in top oven but only broil element worked in the lower of the dual ovens). I swapped elements around but the problem was still the bottom element bottom oven.
So I called the repairman. He replaced the relay board (Part #AP2127301) for the lower oven, and it worked again. Yippee.
But now a year later, I have the exact same problem. Lower element on lower oven is not working (Frigidaire you have got to be kidding)!
However this time I decided to take a look at the relay board myself, to at least save the expense of the repairman. I looked closely at the board and thought I saw a cold solder joint on relay K4. But just to be safe I touched up all the connections on all the relays with flux and a soldering iron.
Works perfectly again !!
Please if you try this, disconnect the power first. In fact if I had to tell you that, then just call somebody.
Oct 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hi my oven is not heating properly. The top coil seems to produce heat, but the bottom one is cold.What gives?
Either the bake element is open, or the relay on an electronic control or thermostat on a manual control is not closing.
Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont lite or work
You say it will not lite ? I must think you have a gas range and you most likely have a bad ignitor. If the range is electric you may have a bad bake element. You can change this easily from inside the oven. Simply unplug the range, then inside you will see the bake element on the bottom of the oven. You will find two screws holding it in. Remove the two screws and gently pull the element out of the hole. I will have two wires attached. You can remove the wires by simply pulling them off, some will be screwed to the element. You can then check the element with a voltage meter for continuity. If you have none the element is bad. Hope this helps and feel free to call if you need further help.
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
217 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
