Question about Gateway Computers & Internet
Gateway loptop computer model MX6435 can't be start up, press power button,you can hear the sound of cooling fan work but then stopped-start-stop for repeat, the screen no any dispaly...
I want new Battery for Gateway mx6435
Posted on Jul 07, 2011
Cooling pad grinding noise
As a temp fix, I've noticed that pressing the plastic circular area under the the bottom of the fan may help to realign the fan's bearings.
Basically push up until you hear the fan stop, then slowly release until you hear the fan starts up again. If it still grinds, repeat the process in a slightly different location of the plastic.
It takes a little work, but until a more permanent fix happens it's good enough.
Nov 03, 2013 | Belkin Laptop Cooling Pad
Dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
Feb 18, 2013 | Dell Precision T3500 Computer Workstation...
Old Gateway system (Desktop), Celeron 800MHz. After being on for 30min to an hour, operating system quits. Monitor displays first "no input" then "power saving" and will indefinitely keep cycling between...
sounds like its an over heating issue,i would check the fans to make sure they are all working and clean.Check that the cpu has thermal paste and that it still good(if its stiff or crumbles when you take off the heatsink it needs to be replaced)also check the memory is seatted all the way in.
Sep 01, 2010 | Gateway (683728192730) Barebone
When it starts it beeps 3 times and then shuts down
It sounds like it might have overheated, first let it cool down for a little while then and try again. If it starts working again, get compressed air and clean out the PS3, and possibly get an external fan to stop so this doesn't happen again. If the PS3 still does the 3 beeps try putting the PS3 in recovery mode by going to the recovery menu. Which can be done by doing the following.
  • Turn off the PS3
  • Hold the power button down; the system should turn on and turn itself off.
  • Once its turned it self back off press the power button intill you hear to beeps
  • After you hear the beeps let go of the power button
  • You will told to plug your controller in and press the PS button
  • Then the recovery menu will pop up
If the PS3 still doesn't turn on it be dead and need to be replaced. Best of luck!
Jul 18, 2010 | Sony Video Game Consoles & Games
Power button blinking red on gateway profile 4...monitor appears to be on, fan is operating, can hear drive starting but computer will not boot up. Checked power to hard drive and ribbon cables, memory,...
1.Check your power supply by using an Analog Volt Meter, you should check if the power supplied by your power supply is stable,
2.Check your ram if it is faulty. try to clean the lids of the ram using an eraser. If still your computer doesnt work, you should find a spare RAM and test if your RAM is working properly.
3.If you dont have any problems with your RAM, you should try unplugging external PCI cards, AGP Cards, on your motherboard and use the internal devices instead, like built in VGA, sound card, Network Interface Card,just to check if there are no faulty devices which stopped your computer from starting.
Hope this will helped you out mate :)
Jan 02, 2010 | Gateway Profile 4 XLb PC Desktop
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Gateway Laptop overheated and stopped working.
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Jan 01, 2009 | Gateway Computers & Internet
Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
Samsung RS2555SL humming noise
don't know this model specifically, but have had loads of problems with these samsung fridge-freezers. the no water in drinks dispensor is probably due to the water bottle at the bottom of the fridge being frozen. this is endemic with samsung the noise you hear is ice hitting fan. samsung use two systems for fan. the one i think you have is separate fans for fridge and freezer and a separate evaperator for fridge and freezer. take of the back plate of the fridge and you will find the fan mounted in it. disconnect the plug and socket connection. you will probably find ice build up round the fan blade. melt off with hot water. the bar you had showing on the "8" is a fault code - the most common fault being the defrost termination sensor. unless you are experienced, this is not really a diy appliance
Apr 02, 2007 | Samsung 26 Cu. Ft. Side-by-Side...
Computers & Internet Logo
168 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
