Question about Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Programing channels without original remote Toshiba tv/vcr/dvd combo unit model #mw24fp1
  • 4234 Answers
SOURCE: Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
Posted on May 21, 2008
ladywinn
  • 5138 Answers
SOURCE: digital reception
If you do not have cable/satellite ,Yes
Posted on Dec 11, 2008
  • 21 Answers
SOURCE: Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Posted on Jan 23, 2009
SOURCE: Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
Posted on May 12, 2009
  • 814 Answers
SOURCE: SAME TOSHIBA MW24FP1 WILL NOT LET ME INSERT A VHS TAPE
You will need to clean the DVD /VCR . It has accumulated dust and dirt in the mechanism and cannot operate normally. This may be only a cleaning job and not a electronic repair. You will need to have the television opened to clean it. You should completely clean all the components in the combination unit. You will need to check and make sure all belts and gears are in good shape and working correctly. Check out the entire television and make sure everything looks good and ready for use. This will save you from having to open the unit again, later to repair and clean the components. This cleaning can be accomplished with compressed air and brushes to clean the circuit boards and mechanisms of all dust and debris. Use small amounts of isopropyl alcohol on cotton swabs to clean off stubborn dirt and dust. After cleaning let the television complete dry and then try using the VCR and see if it works. If it still has a problem and you are sure you have check it out completely you may need the help of a service center to figure out the problem. The Toshiba customer service telephone number is 1-800-631-3811. Call them and ask them where the nearest authorized service center is in your area. You can call them and ask them if they give you a estimate of the repair costs for your model television combination unit. You can then decide if it is cost efficient to have the unit repaired. I hope this information helps you solve your problem.
Posted on Jun 10, 2009
How do I turn off SAP on a Toshiba TV/VCR/DVD combo
The SAP usually is selected as part of setup so returning to the setup routine should allow you to disable it
Oct 13, 2012 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Need to get passed the language screen without remote. Universal remotes won't help. Dog chewed up remote. Once I get beyond the language then I can use cable remote for channels, but I'm not able to...
Unfortunately, this TV doesn't have an alternative for the original remote. I wish the TV buttons could be used in the menus. A programmable universal remote, such as the Logitech Harmony, probably could be made to work the Menu functions. Alternatively, http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=MW24FP1&uuid=12836576773350 has a new substitute remote that should exactly match the functions of the original or a used remote that is an exact match.
I wish that I could be of more help.
Sep 05, 2010 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
I have a Toshiba TV/DVD combo model MD20Q42 and revieved it without the remote. I need to get the television to memorize all channels so I can click the channel up and down buttons but my universal remote...
One option: get a replacement original remote from remotes.com.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=MD20Q42&uuid=12693227936230 (direct URL)
The other option is to get a higher end remote that can be programmed from your computer to match the TV's remote (but check if your tv is supported first).
I hope this helps.
Mar 03, 2009 | Toshiba MD20Q42 20" TV/DVD Combo
Digital reception
Dec 11, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Actually, it's an MW24FP3 VCR unresponsive
After Checking Toshiba FAQ, it turns out that the record button must be turned off to do anything, including playback.
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Mar 04, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Toshiba MW20F51 20 in. TV/VCR/DVD Combo Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
