Question about Eddie Bauer Watches
The hand on the 1-31 days fell off and is lose in the face of the watch
    Genius:
  • 1,970 Answers
Mcdevito75 here, Look for a small watch repair shop in your area for repair.
Posted on Jul 10, 2010
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
How do I open the face of a PHOLM watch?
take the watch to a qualified watch repair person, if it is of value to you. you do not have the proper tools or knowledge base if you are asking here.
if you try to open the back, the tool you use will slip and cut your fingers or hand. it may seem like a simple job, but you don't know how intricate and tiny the screws are that hold the watch together.
Feb 24, 2015 | Watches
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
Mar 16, 2011 | Armitron Digital Sport #45/6967PNK Watch
How do you take the face of the watch off? the second hand fell off and I would like to fix it
This is called watch crystal or watch glass, not face. Do not even try to get it out, as this is not possible from the outside of watch. Nobody takes off watch crystal for refitting hands. For this you have to open your watch case, get the whole movement out and only then refit the hand. If you are not sure how to do that, better go and see watchmaker, or you may damage your watch and then repairs will cost much more than the cost for hand refitting. Rate me, plz.
Feb 19, 2010 | Fossil Metal Casual Quick Turn Sport...
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Dec 30, 2009 | Invicta Watches
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Mar 26, 2009 | Seiko SNA413 Wrist Watch
Watches Logo
141 people viewed this question
Top Eddie Bauer Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Eddie Bauer Watch Expert? Answer questions, earn points and help others
