Question about Jenn-Air Microwave Ovens
My model CG206B cooktop right side burners do not light. I can hear the clicking noise. Gas is coming through b/c I can smell it, and we can light the burners with a match. When I switch these burners to the left side (which I know not to do, but I tried it to see if it would work) they still don't work, but the left side burners do work on the right side. This leads me to think the problem is the burners, not the spark thing or igniter or whatever it's called. What do you think? Can you estimate repair cost? Is this something I can order parts for and fix myself?
  • mkaichele Jul 10, 2010
    just want to get a second opinion
    Guru:
  • 468 Answers
I would advise to remove the top panel and, using a needle, clean all holes in the burner.
The part number for the ignition switch is AP3970762
you can also find the diagram int he below mentioned website:
http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=859957&&model_id=24091#d859957
Posted on Jul 10, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you have already tried to clean the burner’s holes with a pin or a straight paper clip then check the ignition switches which are located beneath the surface knobs as they might have broken. If you think that’s not the issue then you can buy new parts from this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 09, 2010
Automatic burner lighter is not working on my gas range, Amana The Big Oven
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 26, 2011 | Amana Microwave Ovens
Just got this RV. I can't get the range to light. Is there a shut-off valve that I just don't know about???
There may be a valve under the cook top or under the stove. You will of course have to look. There is really no 'standard' or requriement for a valve to be there.
Another reason for this kind of problem is spiders. Spiders love the smell of propane. If you are sure your gas is ON and you do have fuel in the tanks and the tanks are on, (always have the valves of both tanks open all the time (consistent with the highway regulations in your area) and the selecter lever is pointed left or right (never n the middle!)!) remove each burner and blow it out with compressed air. Simply blow it out with your breath or get some 'canned air' at the computer store.
Does your frig operate on gas? You can force it to run on gas (to check it) by disconnecting the 115 Volts; simply disconnect your main cord. Will your frig come on? How about your heater? and your hot water heater?
YOU MUST have a 12 volt battery connected to your RV - a "HOUSE" battery not a "VEHCLE" battery. Everything in your RV runs on 12 volts except the obvious 115 items like the AC and the microwave and the TV. Do not rely on the 15 amp "converter' to supply all your 12 power requirements which often exceed the ability of your converter to provide.
If you stil have no luck, I suggest you turn off the tanks and disconnect the gas line from the stove. Have an associate turn on the tanks while you observe (smell, watch, listen) the unattached pipe. If you hear, smell or see gas, have them turn it off immediately. Reconnect the pipe and test for gas tightness (use a soap water misture. Bubbles = leak. Next step will be to consider the burner controls. This may not be a DIY job. NOTE: Propane is heavy and will sink to the floor. Make sure you have no open lights or flames when you perform the test above and let the gas excape out the open door.
You don't say how old the RV is and given the thousands of makes and models it really doesn't make a lot of difference. Unlike cars and trucks, manufactures of RV's install what they have subject to many substitutions through out the model year. Typically, newer RVs have electronic ignitions while some older RVs have pilots (NOTE: pilots burn precious limited fuel and generate unnecessary heat) and many are simple match light burners.
I hope I have shed a little light on your trouble and you are able to resolve this problem. If you cannot, of course, you will have to have reservations for supper which will make you or your spouse happy.
I hope you enjoy your camper this summer. Thank you for your interest in FixYa.com and please come again.
Jul 24, 2011 | Microwave Ovens
No spark on right front burner. the other burners work fine.
heatman101
Apr 03, 2011 | Microwave Ovens
The burners will not light. I hear a clicking noise but no sparks. oven and broiler works fine
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Jan 16, 2011 | Microwave Ovens
Whirlpool cooktop model # sc8900exb1 ---ignitor is activated with cooktop burners turned off
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 15, 2010 | Microwave Ovens
I have a Viking Professional VGRT Gas 4 Burner + Griddle Cooktop. The griddle stopped working all together. The burners still all ignite and work fine. The griddle does not heat up. When we turn the...
I just had a tech come to my house and he told me that I need a new glow plug, It's the box to the right of the flame. Looks easy to replace, his visit took 5 minutes and it cost me 143.95 (this doesn't include the cost for the part or to have him come fix it, that will be sometime next week) so if you can get the part and do it yourself I would suggest that.
Jul 29, 2010 | Microwave Ovens
Microwave Ovens Logo
150 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
