Question about Bosch PowerStar AE115 Tankless Water Heater...
Need to clean Flow Transducer
I am trying to find out how to remove, clean and replace the flow transducer on my Bosh AE115 electric tankless water heater. I have tried the suggested url that is provided in the customer Handbood for PowerStar heaters (www.boshhotwater.com)without success.
I would like you to send instructions.
3 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: Not sure if my first try worked so will try again.
The easiest thing to do would be to call Bosch and just ask for a new heater for free. The other option is to call Bosch and have them send you all new elements. If there is power, there should be heat of some kind.
Posted on Sep 14, 2010
SOURCE: powerstar 115 tankless tripping reset
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Posted on Apr 23, 2011
My AE115 has power going to it but no hot water
make sure you have the water connections right. the inlet goes on the blue side. Also, your pressure must be a minimum of .8 psi. If not there will be no hot water and the neon will be off. other possible causes might be a crossover in your plumbing or a stuck flow transducer. Here is a link to a guide to explain how to check these items. http://efficientelectricwaterheaters.com/Tech-Support/PowerStar-Tech-Support.asp
May 20, 2014 | Bosch PowerStar AE115 Tankless Water...
Flow sensor
If you change motherboard on laptop computer ... do you expect it to work flawlessly afterwards?
Call Bosch for service manual.
Tankless computers that heat water are problematic for folks... evidenced by working at fixya.
Buy tank type electric water heater at Lowes for 285 and be done with it. Saves money long haul and repairs can be made same day with generic off the shelf parts from hardware store, and unit can be maintained to last forever.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Gene
h
Sep 29, 2013 | Water Heaters
We have power to the system but elements do not come on and heat water when you turn on water. there is 238 volts between all phases. System does not kick on when you turn water on
Control unit or flow transducer. If the transducer(impeller in the clear tube) is spinning freely with waterflow, then the circuit board needs to be replaced.
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
Powerstar AE115. Neon light off - Water not hot.
9:10 times the control board is bad. You are wise to suspect as much.
Mar 31, 2017 | Bosch PowerStar AE115 Tankless Water...
Tankless electric water heater not heating
If you smell it - look fer it. It may be a bad connection on the AC supply line all the way back to the service panel or inside the heater connection panel. Bad connections cause high heat and discoloration of wires or connectors and a serious voltage drop to the appliance.
Jan 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
How to change transducer
Bosch parts are sold at Houseneeds:
Each part comes with service bulletin and disclaimer advising you to have trained service technician install part to save money.
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Bosch PowerStar AE115 Tankless Water...
Not sure if my first try worked so will try again. Bosch PowerStar AE125 Tankless Water Heater. Quit heating water. Water pressure and flow is good. Thermal Cut-outs are good - (not tripped) (Power at...
Sep 13, 2010 | Bosch PowerStar AE125 AE125 Whole House...
PowerStar 125 not heating.
turn the temp to it;s lowest setting and isolate it from the other unit till it fires up, let me know if this doesn't work,, gary1121@ao.com
Jun 07, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Bosch PowerStar AE115 Tankless Water Heater... Logo
168 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
