Question about Maytag M7Y12F2A Air Conditioner
Not blowing cold air
The unit works but the air doesnt get cold just cool
  • Maytag Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
5 Suggested Answers
  • 8 Answers
SOURCE: fan blows.. no cold air... no hot air exhaust blowing
This sounds like you either need to clean or replace the filter, but if the filter is some what new you might want to take a look at the coils just past the filter, if the coils do not have a shine to them then you might want to buy some coil cleaner (i found simple green or formula 50 works great), then you will have to spray the coils with the cleaner, let sit about 10-15 min, then give it a very good rinse with warm water. After that it should work like it is brand new. Enjoy!
Posted on Mar 30, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 38 Answers
SOURCE: lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Posted on Jul 01, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Posted on Jul 06, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
My mistral reverse cycle mss25ss model does not work at all in heat mode. what would be broken?
firstly is the air comming from the outdoor unit cold or warm? if it is cold then the 3way valve is working and it has changed to heating. If it stays warm then it is still in cooling mode. The indoor fan wont come on until the coil temp gets warm enough, ( so it doesnt blow cold air on you straight up). If it is changing into heat mode then the larger of the pipes connected to the outdoor unit should get warm/ hot. If this is not happening then the unit is either out of gas or the compressor is on hollidays and wont come back to work.
May 22, 2012 | Heating & Cooling
Air conditioner isn't blowing cold air like it should
Hello, usually this can be caused by either a dirty filter, evaporator coil or low refrigerant charge.
May 22, 2012 | Goldstar Heating & Cooling
I have a 1999 323i BMW. The AC doesnt blow cold (on cool days it blows cool temperature but not common A/C Cold Air, Hot Days it blows Warm/Hot Air). The heater blows warm air but definitely not common...
First things first.....You must have the air conditioning system hooked up to an a/c system machine and then checked for leaks and also read low and high side pressures. If there are leaks then low Freon (R134a) content and low refrigerant oil can cause the a/c system to not engage the a/c compressor which basically means you will not have proper defrost functionality nor regular air conditioning. Most shops, when working with your air conditioning, will install air conditioning dye to assist them in locating leaks and is the first step in diagnosing all a/c systems. Post the findings after thw
Jan 21, 2018 | 1999 BMW 323 Series
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
The 10,000 BTU portable room a/c unit is not running cold enough
Make sure your vent is closed. check the filter to see if its clean. If you run the a/c you can check your evaporator to see if you have condensation or does it freeze up?
Make sure you have your unit on early in the morning. If you turn it on in the afternoon the humidity might be too much and it will take along time to cool down.
Try those things if that doesnt work then you need a service call.
Jul 10, 2009 | Whirlpool ACP102PR Portable Air...
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Maytag M7Y12F2A Air Conditioner Logo
216 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
