Question about GE Combination 106687 Upright Vacuum
I need replacement filter model 106687 - GE Combination 106687 Upright Vacuum
I need a replacement filter for a Kobalt wall mount vac. Model # kwm508
Go to a vacuum sales and repair depot. I was at one yesterday. they have about anything you need
Dec 02, 2016 | Filter Vacuums
Do you have any GE Combination Vac bagless system in stock and how much
Fixya does not sell replacement parts. Suggest you check with a vacuum cleaner repair shop.
Aug 01, 2016 | GE Combination 106687 Upright Vacuum
I need to replace the filters for my vacuum but I cannot find them for model NV502. Help!
Which filter are you looking for? Is it the foam filter in the bottom of the unit or the HEPA exhaust filter?. Ive found both on Amazon. Amazon com 1 Shark NV500 HEPA Filter Fits Shark Rotator Pro Lift Away...
Mar 23, 2016 | Shark Rotator Professional Lift-Away...
I need a new filter for this model. where can I find one?
It would help if we knew the model number and where you were.
I hope I have been of help and please do hesitate to ask if you have any further questions
Feb 20, 2011 | Vacuums
I got a used filter queen majestic vacuum at a yard sale and want to fix it up and start with new filters where do i get the filters and how do i change them
Well you bought a really great vacuum cleaner. The Filter Queen's are extremely durable and very well made vacuums. They sell brand new for over $2500, so picking one up at a yard sale was a great find by you.
There are several different filters on this model that need to be replaced. Here's a link to a 6 month supply kit that we sell, which contains all the filters needed for a 6 month period:
Filter Queen MediPure Filters 6 month supply
The only other part that you should be replaced on a regular basis is the belt (only if the vacuum has a motorized power nozzle for cleaning carpets). The belt should be changed every 6 months or so. Even if it doesn't break, these belts will stretch out and not work as well as a new belt would. Here's a link to the belt that will fit your Filter Queen Majestic:
Filter Queen Power Nozzle Belt to Fit All Majestic models using a flat belt
Here's a link to the owner’s manual for a newer Majestic model. This is the only one that is available online. Even though it's a newer model, the maintenance and care will be exactly the same for your model.
Filter Queen Majestic Owner’s Manual
I really hope this was the information that you needed. If you have any follow up questions, please don't hesitate to ask them by using the comment box here on the Fixya repair page.
If this did help you, please be so kind and rate my repair helpful, or leave some feedback for me. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Jun 15, 2010 | Filter Queen Majestic Canister Vacuum
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Where can I get a fiter for my GE Combination Bagless Vac model 106687
Greetings,
Your GE is actually made by Eureka for Wal-Mart. Wal-Mart owns the GE brand for vacuum cleaners, and they have different manufacturers (most always Eureka) make vacuum cleaners specifically for Wal-Mart, but in actuality it's really a Eureka vacuum cleaner in terms of the parts (most of the time, in this case for sure).
Your GE model 106687 uses Eureka Dust Cup Filter Part Number 61518. Here's a link to Amazon for the filter;
http://www.amazon.com/Eureka-Model-106687-Filter-61518/dp/B001DPLYAG/ref=sr_1_1?ie=UTF8&m=A13YM4FUDXTJG6&s=generic&qid=1269298852&sr=1-1
The parts Diagram for your vacuum cleaner can be found here;
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/GE106687.pdf
This will give you all of the Eureka part numbers for your GE Stick Vac. I hope that this was helpful to you. If you found this helpful, please be sure to rate the answer as helpful by clicking the 4 thumbs up icons in the top right hand corner.
If you need any other parts, please feel free to contact us.
Thank you very much,
Chris Jones
GoVacuum
Mar 22, 2010 | GE Combination 106687 Upright Vacuum
Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The Durabrand filter can be found at http://www.totalvac.com/accessory/parts/H19030.html
Mar 19, 2008 | Vacuums
Need help with my vacuum
You didn't state brand and model number. Some of these filters can be washed, make sure it is dry before putting it back on. If it is a year or more old, then replace it. Call around to your local repair shops to see they would have a replacement filter.
Mar 12, 2008 | Vacuums
GE Combination 106687 Upright Vacuum Logo
67 people viewed this question
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Are you a GE Vacuum Expert? Answer questions, earn points and help others
