Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
MOTHERBOARD HOW TO OVERCLOCK
As far as i have found, there is no way to OC this MOBO. I have even tried third party OC programs but as soon as i reboot.... poof everything back to the way it was!
Posted on Apr 22, 2008
    Problem Solver:
  • 9 Answers
Download bios updates.....
Posted on Apr 21, 2008
The BIOS for this board does not allow you to change the front-side bus (FSB) nor voltage. However, you can change the FSB on the CPU by connecting pins with either foil tape or a conductive pen used to repair windshield defrosters. For the Pentium e2160 I boosted the FSB from 200MHz to 266MHZ, raising the speed from 1.8GHz to 2.4GHz. The standard voltage and heat sink work fine. To see a photo of the pins you need to connect search for "pentium e2160 bsel 266 mhz" in Google images or try this link:
http://forum.hardware.fr/hfr/Hardware/CPU-Mobo-Ram/4coredual-overclock-sata2-sujet_795475_6.htm
Just remember to reset the motherboard using the reset jumper after you mod the CPU. On the first boot-up the BIOS will ask you if you want to use the 266MHz speed. Answer YES and continue.
I have not been able to get it to work at 333MHz FSB (3GHz clock speed), though this should be theoretically possible with this mother board.
Happy overclocking.
Posted on Apr 23, 2008
What to check/set ddr memory
Your motherboard will automatically set the speed at the highest speed the motherboard and Bios will accept. If your trying to overclock it then you'll need to go to a site like www.overclock.net/.
May 24, 2012 | ASUS Computers & Internet
Set ddrs speed
Good Luck!
May 24, 2012 | Computers & Internet
Overclocking with p5sd2-vm motherboard.
i have no install the sound driver please help to the install...............
Jul 27, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Problem Booting Motherboard After Overclock
hi unplug tour cpu chassis just remove the battery found on motherboard for 5 minutes then put it back inside
Jan 19, 2010 | Gigabyte GA-X48T-DQ6 S775 X48 ATX DDR3...
How to overclock 945GCT-M2/1333 motherboard
Try getting an overclockers BIOS. ECS motherboards don't usually offer the best overclocking support.
Sep 30, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
How to overclock my motherboard ?
there are 2 ways, overclocking using the bios to over clock the memory ( ram ) and also the processor ie changing the multipliers and other tweaks ( which should be in your motherboards manual ) that or using jumpers which are physically on the motherboard but later motherboards use the bios to tweak / over clock your computer.
Apr 13, 2009 | Computers & Internet
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
My processor is 3.0ghz is not detected and i have also 2.6ghz processor is not detected, how can i overclock this.
Download a manual to see how to overclock the BIOS software for your motherboard.  You will need to know you CPU socket number, then model number.
http://www.pcchips.com.tw/PCCWebSite/Support/Category_Support.aspx?MenuID=3&LanID=2
Nov 03, 2008 | PC Chips (M925G) Motherboard
How can I overclock 845gv-m3 motherboard?
according to ecs this is a 478 / fsb 500 ht mobo and cannot be overclocked (now most can be with a bios flash but be carfull the speed you get my not be worth it I find most only get 2-300 mghz & you chance ruining a good mobo).
Oct 24, 2008 | Computers & Internet
Compatible processor
Yes, if you overclock you computer, I believe if you enter your bios of the motherboard, asus already has a pre overclock options. That is if your using a p4 2.8 ghz processor. You can not put a 3ghz processor and overclock it to a higher fsb, your motherboard will literally smoke up but, most motherboards probably can easily detect a non compatible CPU.
Sep 16, 2007 | ASUS P4GE-MX Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
392 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
