Question about GE Deluxe 30" Convertible Range Hood - Stainless-Steel
GE Deluxe 30 Range Hood ---can't find a 2 way bulb (Light/night light)???
  • GE Master
  • 5,128 Answers
The current Convertible Deluxe rangehood from GE doesn't support a two-way (light/night light bulb). You can use an incandescent light with an A15 type (60 watts or less) or a compact fluorescent (A17 or T2) with an ordinary screw base that draws no more than 13 watts. Some models can only use the incandescent light (RN328, JN327, JV338). The recommended compact fluorescents are available from www.gelighting.com (product codes: 85383 or 47486). Check you manual or products.geappliances.com for a pdf of your manual.
I wish that I could be of more help.
(the model of your range hood would be useful to get more information)
Posted on Jul 10, 2010
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
Hood Light Problem
This is a light socket problem, and it has plagued hoods for years simply because grease builds up there and is acidic. One fix is to disconnect the power and wash the socket with alcohol, then buff with steel wool being careful to leave no steel wool behind. After cleaning you will need to re-tension the little aluminum/brass button at the bottom of the socket by placing a screwdriver under it and gently lifting it about 30 degrees upwards. Replace the bulbs with ONLY the stated wattage bulbs indicated on the panel.
Mar 05, 2010 | GE Profile Designer JV936DSS Stainless...
I would like to get a replacement filter for my GE deluxe 30 range hood
A few options for you:
These filters are usually washable. Unless the media is falling apart, they can be washed by hand with hot water and a good dishwashing liquid.
These filters have a metal media for fire safety and your local hardware or home improvement store will usually have this variety of filter media for a few bucks. You can then cut it to size and replace the media in the frame. If the frame is hot, this might not be an option.
You can contact the GE vendor (they may have a website) and find out where you can order a filter assembly,
Dec 15, 2009 | GE Deluxe 30" Convertible Range Hood -...
GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 09, 2009 | GE JVM1441 Microwave Oven
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Feb 17, 2008 | GE Monogram ZV30SSF Stainless Steel...
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
GE Deluxe 30" Convertible Range Hood - Stainless-Steel Logo
422 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
