Question about ElectroVoice http://www.electrovoice.com/products/70.html Amplifier
I recently heard that the EV-757 was the best mic ever made for vocals. What compares to it or even surpasses it in the new line of EV mics? Also, are the new ones American made like the old ones?
    New Friend:
Don't know if I'd go that far. Microphones (like other gear) has specific design characteristics. The EV757 is a great mic and is best suited for female vocals (or Art Garfunkle). I paid $190 in the early 90's ($390 retail). I like dynamic mics for their ruggedness and no ned for phantom power. A condenser mic like a Neumann U87 cost $3,000 but faithfully reproduces. "Best" can only be used in conjunctioon with "for a particular purpose"
Posted on Jun 06, 2013
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
Can you help need the wiring for astatic silver eagle mic to wire up to the yeasu ft-757-gx radio
The best info I can find iis
radio mic
pin5 blue mic ground
pin6 red ptt
pin7 screen
pin 8 white mic
Jan 30, 2015 | Astatic Radio Communications
Eq for male vocal mic on mackie 1604 vlz3
There is no easy answer to this. It will depend on the mic, the speakers and the singer and genre amongst many other things. It will also probably be room dependent too although the overall eq should be able to take this out of the equation to a large extent.
Your best bet is to get someone to sweep the frequency on the mid range with a bit of positive and then a bit of negative eq to find where most affects your vocals then fine tune to your liking. Are you using a bit of reverb/chorus/echo as his can often, when used sparingly, enhance even a good singer. The biggest difference you'll probably find is from using different mics. The ubiquitous SM58 does not suit everyone but is robust, warm and forgiving but if you're after a more pure sound there are many more accurate mics you can try.
Aug 10, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
How can I get a professional sound out of my vocals; what I'm trying to say is how do I edit my vocals to get that studio effect or what ever, like all of that panning and equalizing business and so...
first, you need a hugh quality studio mic or a seinheiser, sure sm 58s and cheaper mics sould muffled compared to real studio mics.
whatever mic you have, the key to the studio sound os overtracking. record your vocals, singing exactly the same, 2 times, and pan 1 take to the right, and another to the left. this will give it as chorus effect.
then, use an eq to drop everything below 500 hertz about 20 decibels or so, thios will make it cut above the pusic and sound clearer.
after this, you can add effects such as delay, reverb and maybe chorus, but too much effects will muddy the sound.
Dec 01, 2010 | Electronics - Others
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Regards,
Gerard
Feb 17, 2010 | Shure SM57-LC Professional Microphone
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
MXL 990 has really low output
These are really cheap mics! I have two dozen of them because what I do requires the mic to be expendable. The capsule is pretty fragile and just a little drop or hit to the mic can drastically alter the frequency response and output level. If you record with it and it has a hollow sound I would bet this is what happened. If you can generate white or pink noise out of your system, then record it. Just hold the mic in front of the speaker. Play it back and compare the tone of the recording to what you just heard. Hollow? There you are!
Aug 28, 2008 | MXL 990 Professional Microphone
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Vocal problem
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check
remove the mic ball
the part which the mic ball is is covering is the voice coil.
try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced
try using your tester- test the impedance- there should be 500- 600 ohms reading
(sean.delcarmen@magicmic.com or customerservice @magicmic.com)
Dec 18, 2006 | Magic Sing Along Consumer Microphone
ElectroVoice http://www.electrovoice.com/products/70.html Amplifier Logo
934 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
