Question about Dirt Devil POOL CLEANER FOR ABOVE-GROUND POOLS
Dirt devil pool vacuum wont move
My dirt devil in-ground pool automatic vacuum is not working. It used to shake which would make it move. It still has suction but does not move.
Cannot find part replacements for my Dirt Demon pool cleaner. I need a flapper plate. Thanks for any help.
Posted on May 26, 2011
  • 640 Answers
If one of these pool cleaners is not working, you likely have an obstruction in the flapper. That would explain why you have suction and no movement. With the pump off, turn the cleaner upside down and check for any twigs, rocks, etc. in the flapper. If you don't see anything or see something you can't reach with your fingers, remove the base plate with a flat head screw driver and check there. The base plate is where the waste is collected.
Posted on Mar 23, 2011
Dirt Devil Rampage Robotic Pool Vacuum wont climb side and stays in deep end all the time?
If a pool vac is not climbing the side of the pool this is one of several things main things . a blockage in the pipe (try inserting garden hose to flush it. or insufficient vacuum at the skimmer box (Test with your hand) or a break inside the unit - if the third, you probably need to take it in for repair.
May 17, 2014 | Dirt Devil Rampage Robotic Pool Cleaner...
Our dirt devil pool cleaner keeps sticking to the pool floor and will not move around, what do we need to do?
Make sure that your unifram is installed with the opening in a vertical position. If it is horizontal, you pool cleaners line will not have proper suction. You will also want to check for obstructions in the flapper that would cause the cleaner to not move properly. Finally, make sure that this is the proper cleaner for your pool size. If you have an in ground or very large above ground pool, it is possible that the pump you are operating with is too strong for the cleaner to move properly.
Apr 09, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Can't get dirt devil to go
There are several things to check if this type of automatic pool cleaner stops moving. It is typically a blockage in the flapper area. Turn your pump off, remove the cleaner from the pool, and turn in over to view the flapper. The flapper should move freely and their should be no obvious stones, twigs or other debris clogging this area. If you see debris and can't remove it with your fingers, remove the base plate (plate where the debris goes when vacuuming). Using a small flat headed screwdriver, push on one of
the two tabs located on the side of the base plate. Release the plate and remove the flapper. You can then clean it out. You should also check your skimmer and pump baskets and empty them if they are full.
Feb 26, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Replacing the drive track.
The tracks for the Dirt Devil Rampage pool cleaner are the same as the AquavacTigershark. Simple look for the parts for the Tigershark. Its the same exact thing.
Jun 20, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
My resently purchased Dirt Devil pool cleaner vacuum for above ground pools does not have any suction. It was assumbled the exact way the manual said. What's the problem?
Sometimes u have to use the return water that enters your pool to fill up the hose with water u use to get all the air out of it, its kinda like priming it. or u can submerge the hose all the way. And if that still doesn't work then sometimes giggling the hose might get it to start suction
Jun 02, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
How to set up a d2000 automatic pool vacuum
Here is a copy of the users manual for these above ground pool cleaners. It has detailed instructions and pictures for set up. This should help.
http://www.backyardcitypools.com/images/BWP/Dirt-Devil-D2000-Manual.pdf
May 21, 2010 | Dirt Devil Above - Ground Auto Pool...
I NEED PARTS FOR A DIRT DEVIL RAMPAGE POOL CLEANER AND NEED MANUA
You can buy replacement rubber threads for this model from any store that sells automatic pool cleaners. They are easy to install and the instructions should be included in the packaging. This is something that you should easily be able to handle yourself.
Jul 13, 2009 | Dirt Devil Rampage Plus Robotic In Ground...
Cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
Dirt Devil POOL CLEANER FOR ABOVE-GROUND POOLS Logo
839 people viewed this question
Top Dirt Devil Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Dirt Devil Pool and Spa Expert? Answer questions, earn points and help others
