Question about GE WPRB9220C Top Load Washer
I have a ge profile wprb9220c that will work but will not drain
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
Model WPRB9220C draws cold water when it's supposed to draw hot.
Your hot water inlet solenoid has failed and needs replacing.
Mar 11, 2012 | GE WPRB9220C Top Load Washer
My old GE Profile top loading washer is overflowing during the fill cycle...It moves into agitation OK but doesn't stop the fill. I have to manually turn off the water during the fill. Fill switch works...
loosen the back screws and push the top forward, its got clips in front that just shift in, then you mast carefully lift the top due to the wires and vacuum pipe that control the level, just unplug the supply
Dec 12, 2010 | GE WPRB9220C Top Load Washer
GE profile dishwasher (2004) will not drain properly. Is the drain clogged? If so, how do I open and clean it?
check the hose first alot of times the hose canbe clogged . disconnect the hose hit the drain on the machine and normally the clog will be seen. if that doesnt work then its the drain pump thats clogged.
Mar 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Ge PRofile Mod # wpsr31001ww
CHECK THAT DRAIN PUMP IS NOT CLOGGED, THEN CHECK DRAIN HOSES, . IF NOT CLOGGED, IF GOOD THEN CHECK PWR TO DRAIN PUMP. IF U GETTING PWR TO PUMP,AN NOT SPINING OR HUMMING REPALCE PUMP
Aug 19, 2009 | GE Profile WPSR3100W
My GE Profile doesn"t drain completly, leaving about 2" of water.
Sounds like a water level sensor is on the fritz. The drain valve is probably opening if the level drops at all.
Jul 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
May 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PDW8280J10SS: Water won't drain. I
Can you get the water to drain at all in any cycle? If you can, then its possibly the control module .
If you can't get it to drain in other cycles or when you cancel the cycle, then its a possible clog in the drain outlet hose, drain solenoid, or screens.
Here is a good detailed link to check out that explains about it:
http://www.applianceaid.com/gedishdrain.html
Heres another link about general dishwasher draining issues:
http://www.applianceaid.com/drain_wash.html#drain
Apr 16, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE PROFILE
It sounds like your drain hose is kinked or blocked, or maybe the pipe that the drain hose drains into is blocked. Somehow water is now being allowed to get out of the machine at the end of the cycle and is staying in the machine. Check those hoses and pipes.
Jul 11, 2008 | GE Profile Harmony DPGT750EC Electric...
Open Questions:
See all GE WPRB9220C Top Load Washer Questions
GE WPRB9220C Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
