Question about HP Office Equipment & Supplies
After I replaced the black ink cartridge,I couldn,t copy or print from computar.
  • tyamaki Jul 10, 2010
    I shook the cartridge, itm did not solve the problemI wanted to clean the inkjet head but I don,t know how torun the head claening problem.
    President:
  • 4,070 Answers
Hi! Please try this... pull out the black cartridge and shake it, ink may spill a little during the procedure. Put the cartridge on the printer again. Please run head cleaning to sip the ink to the ink line. Few runs of head cleaning can make it work again. Hope this helps and have a good one!
Posted on Jul 09, 2010
  • dj_relly999
    dj_relly999 Jul 10, 2010
    Cleaning the head is a sensitive procedure. I suggest that you check the ink well for dried inks thats clogging the ink flow. This can cause a no print too.
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have a hp officejet pro 8500a and it has started leaving a black line on all copies when the original is fed thru the ADF. What is causing this??
Hi, Change first black color print head cartridge just open cover then replace black print head cartridge.close cover wait for ink cartridge reinitialize if ready print test again.if same print having black line all copy needs to replace also black ink cartridge.
Jun 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
Canon MP140 fails to print
I don't think that has anything to do with reaching the board of 5000 copies. Your cartridges have no chips on them or anything. You might actually have a problem with your black ink cartridge, as the printer is telling you. Remove the black cartridge, gently wipe the contacts with a dry cloth and put it back in. Hold the "resume" button (triangle in circle) for about 10 seconds to try and reset your cartridge. If none of that works, I suggest you buy a new black ink cartridge.
Apr 07, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
14 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
