Question about Kohler 12 kW Emergency Power System - 12RES-L
Kohler 12k a few yrs old, will not crank, i hear a short click but then cc1...oc error...new starter and selonoid...all fuses ok
  • 10,865 Answers
Hello. As these age, there is a tendency for a nonconductive layer to form on the connections between battery and starter, battery and ground etc. Disconnect these cables and clean then with emery cloth. Clean the battery posts. Reconnect all making sure the connections are tight. Spend extra time where the ground wire connects to the side of the unit. Scrub it clean and connect it tightly. Then REcharge the battery and crank it over. It should take off.
Posted on Jul 09, 2010
Starter draw amps kohler cv16s engine
The starter windings may be shorted, that would explain the draw, if the starter is ok then the engine has really got a problem.
Sep 27, 2016 | Garden
The starter on the 12res Kohler generator just hums (spinning sound). It doesn't engage the flywheel. Do I need a new starter?
OC is over crank failed to start. It will normally try 3 times before giving this error. You need to disconnect the battery and remove the starter motor, make sure it is free to move / spin. Either the starter has seized or the engine has siezed. Make sure the engine is free to rotate also, once you remove the starter you will see the engine flywheel there, removing the spark plugs will make it easier to rotate the engine. I would guess it is more the starter.
Jan 06, 2014 | Kohler 12 kW Emergency Power System -...
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
Sep 11, 2013 | Kohler Electrical Supplies
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
1993 OLDS CUTLASS CIERA 6 CYL. AUTO STARTER DOES NOT CRANK ENGINE. i KNOW I NEED TO REPLACE THE HARMONIC BALANCER SINCE IT IS RATTLING. I DROVE THE CAR FOR ABOUT 30 MILES. A FEW DAYS LATER. I THEN...
are you sure the engine isn't locked up can you manually turn engine??
try hitting the starter it may have a bad connections from a worn brush if by
hitting it starts cranking you no the starter needs replacing.
Jul 03, 2011 | 1993 Oldsmobile Cutlass Ciera
Have Kohler 12RES. Gives a CC1 code thenan OC code. Have checked out the starter, it's OK, have cleaned all ground cables and connections and had the battery tested it's OK. Where do I go next?
check your load wires there probaly reversed. I had the same problem friday. The week before the electrican wired it. did the same cc1 then oc. had a generator company come out it was the wireing. my load and netural were reversed.
Sep 07, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Nov 11, 2009 | Kohler 12 kW Emergency Power System -...
Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Apr 20, 2009 | Electrical Supplies
Kohler 12 kW Emergency Power System - 12RES-L Logo
140 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
