Question about Trekstor Datastation Pocket x.u / 87336 160GB SATA 2.5" Portable 160 GB USB Hard Drive
Trekstor 160gb datastation maxi n.u not recognised
When connected Trekstor datastation lights solid blue and you can hear the external drive whirr at first but nothing shows up on laptop to show it is connected. It is apparently not recognised yet it works on friend's computer. Nust something be wrong with my laptop? Is it possible there is not enough memory on my hard drive to tun the external drive?
5 Suggested Answers
  • 12 Answers
SOURCE: DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Posted on Jul 29, 2009
  • 7 Answers
SOURCE: Trekstor TrekStor DataStation m.u stopped being recognised by PC
Have you tried going to the manufacturer's website and downloading and installing the drivers for your product?
Posted on Sep 03, 2009
lock123
  • 6831 Answers
SOURCE: I have Trekstor Datastation maxi 160Gb hard drive,
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
bronk50
  • 27725 Answers
SOURCE: My computer does not reconize my Trekstor
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Oct 04, 2011
I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I have a Trekstor 160gb external hard drive just stoppede working. I can hear a very loud rattling noise how do i fix it. Please help
If it's making rattling noises, it's failing (or failed). The only repair is a new drive.
Sorry for the bad news...hope that's helpful, however.
Jan 12, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I have Trekstor Datastation maxi 160Gb hard drive, I dropped it, making a terrible clicking noise, laptop or telly won't see it when plugged in, trying to remove casing, took 3 screws a long bottom, can't...
Hello
Click HERE.
Kind regards
Andrea
Nov 08, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
My 750GB TrekStor external HDD failed. The light at the front of the device went from BLUE to RED and the machine seems to start to boot up the clicks a few times and then nothing. I cannot view the...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
I have a external Trekstor DataStation maxi 500 Gb hard drive. I now have encountered a constant red light and when this happens the drive is not visible in Explorer. When I turn off the power and then...
At the least, the device is "unreliable", and it would be wise to replace it, either by exercising the warranty (if the warranty still is valid), or by opening the enclosure, removing the disk-drive, buying a new (and compatible) disk-drive, inserting the new disk-drive, and closing-up the enclosure, to create a "new" external storage-device.
Sep 18, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Sep 03, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Not loading
You will need some kind of disc utility.
Open the utility with the drive connected and it should show up in the options of drives.
You should then be able to format the drive.
It should then be usable.
If not take it back to the shop..
Dec 16, 2008 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor Datastation Pocket x.u / 87336 160GB SATA 2.5" Portable 160 GB USB Hard Drive Logo
51 people viewed this question
Top Trekstor Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Alun Cox
vojvodabudva
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
