Question about Kenmore 64722 Top Freezer Refrigerator
I need a manuel for my top freezer refrigerator by Kenmore purchased in 2008
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 102,366 Answers
Http://www.managemylife.com/mmh/owner_manuals/6003/
KENMORE-Top-Mount-Refrigerator-L0504597?brand_name_search=64722
Posted on Apr 27, 2011
Kenmore model# 79573966 - Top Freezer Ice is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Kenmore Top Freezer Refrigerator
Kenmore refrigerator with top freezer purchased about 8 years ago. The freezer isn't freezing food thoroughly and now the refridgerator is not keeping the food cold enough. What could be the problem? ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 05, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Refrigerator purchased March 2008, model # 59665969700, freezer on bottom. Refrigerator stops being cold. Freezer seems to get colder, icing up on back interior.
That icing up on back interior im assuming is in the freezer. If its a layer of frost, you have a defrost problem, and should check continuity through the defrost heater and the bi metal thermostat, both located on the evaporator coil behind the back wall of the freezer. If either fail, replace, if both of those pass the check, then your defrost control is failing to switch into defrost and needs to be replaced. If the icing up is like frozen sweat drips on the back wall, replace the evaporator fan motor.
Dec 10, 2010 | Kenmore Refrigerators
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
Up box freezer works fine but low box refrigerator doesn't work
Good day,
2 hours isn't enough time. Doors open, unplugged, minimum of 24 hours, Ideally with a floor fan blowing into the machine.
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore model# 106 44563600 freezer gets cold refrige stays warm
There is a fan in the freezer that delivers cold air to the refrigerator compartment. Check to see if it is blocked or possibly not running at all.
If not working, a replacement can be purchased through www.sears.com under the parts direct tab. Just enter your model number and search out the part.
Aug 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water present in refrigerator compartment
probable cause is the defrost element in the bottom of the freezer compartment allowing ice to build probable need to replace defrost element
Oct 11, 2008 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 64722 Top Freezer Refrigerator Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
