Question about Jl Audio Car Audio & Video
I have a JL total mobile audio T500.1 mono amp and it was playing then all the sudden it stopped and the power light which is usually green is now red and stays red and no sound comes from the subs any suggestions or ideas?
  • 407 Answers
This happens when the amp goes into protection mode. 90% of the time, it means there is a short or has another issue inside the unit and has to be fixed or replaced. Hope this helps and good luck!
Posted on Jul 11, 2010
Hello, I've Got the JL Audio 500/1 and I am running two 15" Kicker Comps. in a sealed box and bridged to my 500/1 and for some reason all of a sudden the amp now powers off then on none...
If your sure the unit is getting the correct power, check the ground cable, make sure it is connected to a clean surface. (remove any paint where the ground is connected.) Double check your wiring. Make sure all of your connections are good. Do not forget the fuse holder, check it too.
Apr 03, 2011 | Jl Audio 500/1 Car Audio Amplifier
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
I am wondering what amp i would need for 2 JL Audio W3v3 - 2ohms. I am looking for something around 200. SHould I go with the Mono block and how many watts?
well you can go a couple different directions. you can wire them parallel or in series. parallel will get you down to about 1.3 ohms at the amp and series will get you close to 4 ohms. you need an amplifier thats stable at either of those impedances. the lower the resistance (impedance) the more power your going to get to the subs. I manage an electronics store and specialize in mobile audio/video. we are a 'Signature JL Audio Dealer' so i like to say i know the product line very well. JL makes an amplifier that is stable from 1.5 to 4 ohms and will put out the same amount of power at any impedance in that range which is really nice. Its called their 'Slash Series' you are looking for a JL Audio 500/1 amplifier. Grab an 8 gauge amp kit (4 gauge would over do it) and wire 'em up. Enjoy!
Mar 17, 2010 | Jl Audio 10W3v2 Car Subwoofer
Fried amp
Hello zadiel89,
Out-of-warranty JL Audio products are normally repaired through JL's authorized dealer network.
To locate your nearest JL dealer, enter your zip code in the box on this page, select "radius" from the drop down, and click "find".
http://mobile.jlaudio.com/dealerfind.php
You can email JL directly at: technical@jlaudio.com
Hope this helps.
Aug 21, 2009 | Jl Audio Car Audio & Video
I HAVE A JL AUDIO MONOBLOCK AMP 250
It indicating that the power output is too loud and possibility of speakers may get damaged if played at this volume for long periods. When the loudest sound is played the led light mightshow its loosing its brightness and dims in time with the sound level.......................sodeep
Jan 17, 2009 | Jl Audio 500/1 Car Audio Amplifier
If my jl amp e1200 is on green, but no power is going to the sub
your audio wires from the head unit have been pinched or discontected or the head unit is not putting out a signal
Nov 29, 2008 | Jl Audio E1200 Car Audio Amplifier
500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
JL 1000/1 Amplifier
mine did that. i cleand the battery wires and hook ups now it works fine.
Jul 24, 2007 | Jl Audio JL1000 / 1 Car Audio Amplifier
Car Audio & Video Logo
454 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
