Question about Kenmore 24032\24036 Top Load Washer
Washingmachine shuts off at spin and will not drain
This is a kenmor model 110.26292690
    Problem Solver:
  • 12 Answers
Very good advice. Always do any repairs with the appliance unplugged. Good to turn the water off as well. When washer is full of water very hard to move. Try and get the drain hose and lower the hose into a bucket and drain the water. Popping the washer top can be accomplished by pressing in two steel springs with a small flat blade screwdriver and carefully moving the top toward the washer console. Lid switch can be checked without moving the washer. Clogged filter and pump can be a problem on some models.
Posted on Jul 11, 2010
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26292690&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jul 10, 2010
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Kenmore washingmachine motor starts clicking when it starts spinning.what causes the clicking sound?
DOes it hesitate to rotate the drum at full speed?, If not, the dog gears inside the shaft may be worn and not grabbing at full engagement
Jan 25, 2010 | Kenmore Washing Machines
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Amana washingmachine wont drain
Check the drain hose and the drain line, if you do not find any obstruction clogging the drain lain, then test the drain pump and the drain pump solenoid.
See also WM won't drain.
Oct 25, 2008 | Amana 3.2 cu. ft. Top-Load Washer
KENMORE TOP LOAD WASHER - MODEL # 11022422100
hi. thanks for the question . i would check the lid switch ,on that washer. it could be the problem thanks. the appliance doc
Oct 05, 2008 | Kenmore Elite HE4 Electric Dryer
Not spin
check the brushes on the motor it sounds like they need replaced
Dec 18, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore
Check out the drain system. It could be something as simple as a pinched drain hose or a cloged pump.The trouble shooting sheet is behind the kickplate or under the top. This will walk you through the proublem.
Dec 07, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washingmachine
It sound like a motor or a belt issue. Open the machine and look for belt's condition and does the motor spins. Good luck!
Aug 05, 2007 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
137 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
