Question about Laser Lexma G Plus Mouse M231
I have a lexma keyboard which i purchasaed yesterday - anyway i have had probs with sys and ha d to do system recovery after that the keyboard installed automatically - its attached to my vaio laptop - however the top row of alpha keys ie from q to p do not work - is this because i need to update the drivers from windows update or is it anothwer kind of problem ? thank you ps the sytem recovery recoverd windows from xp from 2005
My lexma cordless laser mouse stopped working it
I know it may sound simple but did u change the battery?
Aug 19, 2013 | Laser Lexma G Plus Mouse M231
Keyboard goes to sleep
hello, just so you know that the keyboard does not go to sleep, but to answer your question; the problem is within the control panel>power options, check the settings for your system and see what options are there for the computer to go to sleep other than that try a different port on your computer, let me know the outcome.
Dec 17, 2017 | Logitech Internet 350 USB Keyboard
Some keys didnot work. num and litters
First, try to find out if the issue is related with the hardware or software..
1. go to BIOS
2. press the alphabets which are not working (if you get beep the prob is related with software if not the prob is with hardware)
----------if its hardware related------
1. power drain by removing ac adapter, battery n other accesories connectd
2. go to BIOS n set it to BIOS default
3. check if its working in BIOS page which are not working in the desktop screen(if its not working, the prob is related with the hardware issue. it has to be given for service
--if the prob is related with the software--
2. do system restore (all programs -> accessories -> system tools -> system restore)
3. try BIOS default
4. Update BIOS
5. Uninstall the drivers
6. restart
7.try system recovery
(if it doesn't work, its to be given for service)
let me know if it works
Jun 16, 2011 | Toshiba Satellite A40 Keyboard
Msg Opening Prob. N70
As you said You deleted SOME SYSTEM FILES
  • Try to avoid editing in System files if YOU R NOT SURE ABOUT THE FILE
Anyway you might be deleted sys file supporting to open Msg....
Now Do following....
  • Press CALL button
  • Press *(Star)
  • Press 3
  • Press Power ON
HOLD IT until it appears/ Blinks Nokia TWICE....Or for few minutes....
YOU ARE DONE.......ENJOYYYYYYYYYYYYYY........!!!!!
AM HERE too
Mar 28, 2010 | Nokia N70 Cellular Phone
Hp pavilion dv 6000 keyboard not responding.Some of the keys will not respond at all. I checked the drivers and tried to update, but says most current installed. It has been doing this for about 6 months....
You need to check in the BIOS if the keys when typed does make beeping noise. Set BIOS defaults.
If the keys are still not working than boot the sys to the recovery manager and press ctrl+d to open the CMD box and test the key board there.
Boot the sys 3 times to BIOS and set BIOS defaults,
If it doesnt work try the latest update and drivers for the sys. If it doesnt work that means the keyboard needs to be repaired
Feb 08, 2010 | HP Pavilion dv6000z Notebook
Completed a microsoft update and upon reboot the screen goes blank after the MicrosoftXP logo screen . I can hear the normal music etc. Screen is on not completely black. I see nothing in the F2 setup menu...
Try to load the sys in the recovery manager trough the F10 key and do a system restore to a date previous the update.
If that doesnt work than u have to load trough the safe mode trough F8 and do the sys restore.
If that doesnt work u will have to do a recovery on the sys.
Turn off the Windows update its no god use to ur sys
Feb 06, 2010 | Computers & Internet
My LEXMA Panda 10c webcam doesnt work on msn
Okay MSN only support so many camera first you want to check is your camera on there list?
If so check the following:
  1. Reinstall drivers
  2. Reinstall messanger
  3. reinstall operating system if those two does not work.
If the problem is not resolved with the solutions above consider another alternitve camera such as logitech or the lifecame 3000 from microsoft. I am sure there might be something fouled up wit h the messanger or the OS.
Only a positve rating will be accepted for your FREE answer today, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 09, 2009 | Microsoft LifeCam VX-1000 Webcam
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
May 15, 2009 | Compaq Armada E500 Notebook
Win32k.sys file corrupt
When this occurs and your not able to go into safe mode, then 9 out of 10 times the hard drive has failed. However, there is still that one time, and that will be an operating system glitch. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive won't format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Aug 24, 2008 | Toshiba Satellite A105 Notebook
Error 10E716045D
When I first trying system recovery the recovery would complete and when rebooting it hang at mup.sys in the drivers, now I get this error 10E716045D.
Toshiba A105-2716
Apr 18, 2008 | Toshiba Computers & Internet
Laser Lexma G  Plus Mouse M231  Logo
53 people viewed this question
Top Laser Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Robin Hill
Robin Hill
Are you a Laser Computer and Internet Expert? Answer questions, earn points and help others
