Question about Sony BRAVIA KDL-32S2010 32 in. LCD Television
I need lcd screen Sony BRAVIA KDL-32S2010 - Sony BRAVIA KDL-32S2010 32 in. LCD Television
  • 11,361 Answers
Try contacting www.shopjimmy.com
It is not going to be cheap if you can get one, it will be more than the TV is worth.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 10, 2010
Can a Sony bravia kdl-32s2010 be fitted to the wall on a bracket as it looks like all the connections at the back would be behind the bracket plate if one was fitted
It can for sure.
https://docs.sony.com/release/KDL26S2010_instal_wall_mount_bracket.pdf
I'd just find one that works. Some have vertical mounting brackets that may avoid the connections and others are flat plates that might interfere.
You can also use spacers to keep the plate off the actual rear surface. I've used plastic spacers to give me additional room for my hand between wall and TV on the one wall mount that I have that doesn't have an arm to swing it out from the wall.
Mar 28, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Vertical shadows every 3" on sony bravia 32 about 1/4" wide
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
Feb 06, 2018 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Kdl-32s2010 .... after 1 hour, screen goes blank. I can get to the menu and switch to digital then back to analog and it works fine for another hour. it is hooked up through a regular cable to a sattelite...
The sattelite box have issues,tries unplug,replug the box back like about an hour later for it to reboot and resetting and upgrading it softwares.This tv problems switching modes to digital and to analog again back and forth should be solved.Still happening the box have problems,call ur sattelite provider change the reciever box.
Apr 04, 2011 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
No picture, medium gray screen, sound volume will go up and down, but no "sound" just static.
Hey!
Dude there is a problem with the ( TV turner card ) some component is being over heated or has leak this card should be changed .
This card feeds the TFT with the voltage needed to glow and picture, sound, so should be checked.
Good luck
Nov 30, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
My toddler has wacked the screen and cracked the screen!!!!! It still works fine aside the damage, is it worth getting it replaced and what would the rough cost of this be?
If the model is kdl-32s2010, then the part number to use for the LCD panel is: 1-802-060-23. The cost of this part is $1749.99 plus shipping with a core return refund of $1100.00. This means that you will initially pay the $1749.99 and will be refunded $1100.00 when you return the defective panel. The final panel cost is $649.99 plus shipping. You make the call about whether or not it is worth it.
Hope this helps,
Dan
Nov 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Apr 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Apr 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Need a Replacement LCD Panel Module for a Sony Bravia KDL-32S2000
I don't have a listing for the model that this is posted under, but the replacement panel for similar model KDL-32s2010 is $2232.55
I would expect the cost of your replacement to be similarly priced. If you post your specific model, I will attempt to get the exact price and part number.
Dan
Feb 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-32S2010 32 in. LCD Television Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
