Question about Compaq Presario 5000 PC Desktop
Computer is extremely slow, no sound, hard to get online, printer and scanner does not work
  • 808 Answers
Update ur Bios and use reg in out
Posted on Sep 03, 2010
  • 570 Answers
You can use a registry cleaner to clean up your computer and then make your computer faster,Why?the reason is that there may be some registry errors and remnant,corrupt files and temp files in your computer to cause "computer slow".
Every time you install and uninstall software on your computer and surfing online you create junk in the computer registry.over time, the registry can grow to enormous proportions, especially if the various programs you've installed do not do a good job of deleting and/or updating it's Registry entries.You need to scan and clean your computer with registry cleaner to make it fast.Good Registry Cleaner will improve your computer and Internet performance dramatically!
There are some comparison and review of TOP 5 registry cleaners.
http://www.speed-up-your-pc.com
You can download and scan your computer for free.
Please rate me if this solution works for you.
Thanks......Have a great time.
Posted on Jul 10, 2010
Xerox Phaser 5550 slow printing
upgrade firmware of the printer .. you can do that from the support site ..
if that does not help, then call 1-877-805-1027 for expert help
Oct 15, 2015 | Xerox Phaser 5550n Laser Printer 50ppm...
Computer runs slow
It sounds like you might have some type of virus or other malware.
Here's some things I would recommend to start with:
  1. Install and run a scan with the free version of Malwarebytes, removing any malware items found.
  2. Run a second scan using the ESET online scanner, removing any malware items found
  3. Install and run ccleaner to clean up unneeded temporary files.
If these steps don't resolve the problem, you may want to seek professional help.
Links:
Malwarebytes Anti Malware
Scan Online Virus Scanner from ESET
CCleaner PC Optimization and Cleaning Free Download
Jan 31, 2014 | Computers & Internet
Extremely slow running
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Mar 29, 2013 | eMachines T5274 Desktop PC
SIR I AM USEING PANASONIC KX-P1150 MULTI MODE PRINTER SINCE LAST 8 YEARS VERY WELL. NOW THE HEAD OF THE PRINTER NOT WORKING PROPERLY. SO I WANT A NEW HEAD OF THIS NEAREST MY LOCATION .BHILWARA...
The printheads are extremely hard to source - even used or refurbished...however you can order complete replacement printers online for about $140 online.
Jul 02, 2011 | Panasonic KX-P1150 Matrix Printer
Hard drive problem detected instructed to check users manual but cannot locate manual everything is very slow...Is it time for a new cpu? Computer will turn itself to a black screen with the...
Hi do you here any noise from the hard drive?
If so you should backup your data and buy a new hard drive, install it on your pc and install windows and all of your programs again. This is because the noise you hear means that your hard drive is getting broken
Let us know if you solved your problem
Mar 06, 2011 | Gateway E-6000 PC Desktop
The scanner, which used to be fast, now runs extremely slow. It takes about a minute and a half for the Dell AIO Center software to load, nearly 3 minutes to preview, and 2 minutes to scan. So just to scan...
Scanners speed is influenced by the quality chosen in document productions. Selecting impressionful color saturation requires time to produce results. Use the menu buttons on the scanner to select least saturated color pixels.
Feb 02, 2011 | Dell 968w Printer
Memory keeps decreasing and slows computer
What do you mean by decreasing?
This sounds like a leaky / bad programmed application
or more likely a computer-virus.
There are many free online-scanners available
TrendMicro, McAfee, Symantec
http://www.kaspersky.com/virusscanner
http://housecall.trendmicro.com/
http://www.bitdefender.com/scanner/online/free.html
http://www.eset.com/online-scanner
Jul 18, 2010 | Compaq Presario 5170 (320750-003) PC...
Scanner to computer slow
yep!
you may add additional image memory,
*this is assuming that your computer runs fast.
May 20, 2010 | Panasonic DP-C264 Color Copier
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Compaq Presario 5000 PC Desktop Logo
221 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
