Question about Acer AL1716 17" LCD Monitor
As I entered in the webpage just a moment ago: The monitor shows the ACER logo but then goes black. Won't show data from it's regular computer or another. Another monitor works fine on that computer. = problem is the monitor. Q: How do I open the back of the monitor to check data line connections? Are two small screws and a locking slot. I can't figure how to unlock the locking slot.
  • 11,361 Answers
Here are the service manual:
http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1716&kategoria=monitor&kat2=schematics
Use small flat blade screw driver, starting at the bottom edge and work your way around, look for bad caps with leaking/bulging top.
If you are not sure what you are doing and do not have the proper tool to solder and unsolder, please leave it to the pro. There are high voltage inside that can kill you.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 11, 2010
Model: S271HL DBID Acer monitor turns on shows logo and goes black
sounds like your computer is freezing up after it posts check your cpu temp that sometimes will do it
Jun 20, 2014 | Acer Computers & Internet
Acer is going straight to a black screen after the acer logo in startup....it just shows a tiny blinking line. It goes no farther. I need help fast
Apparently your Acer cannot find the operating system. As soon as the Acer logo comes up, there should appear in one of the bottom corners "F" & a number should appear. Immediately start pressing that F number (top row of keyboard). This should take you to a boot screen. Scroll down to boot sequence. Hit enter. Make sure boot-up sequence is CD or floppy drive first, second should be HDD, then escape. Restart computer. Should then boot off CD drive. I am assuming you have an operating system (XP, windows, etc.). Let me know if this doesn't work.
Apr 07, 2013 | Acer Aspire 5734Z4386 Notebook
My Acer X193w. My monitor comes on and says cable not connected but when I connect the VGA cable the screen goes black even though it is still on.
VGA is an analog connection, so you should connect it to your monitor BEFORE starting up the PC. Otherwise it won't show anything
May 04, 2011 | Acer X193W LCD Monitor
Acer al2416w acer logo comes up then light goes yellow and no signal detected shows for about 20 seconds then black screen only
Try opening it up, and reconnect the connectors on the three different boards. Worked for me for a while.
Oct 14, 2010 | Acer AL2416WBSD 24" Monitor
When I boot up my computer, it takes my Acer monitor 20 minutes to show the desktop. It flashes the Acer logo, then goes black, then flashes again, and repeats till it finally comes on. Could it be a...
It's probally the inverter board that drives the backlight in your monitor is failing causing the digital board to reset. I think Acer has a 3 yr warranty. If the monitor is less than 3 years, I would call them and ask them to repair it. They will fix it for free if it less than 3 yrs old, it will only cost to you is shipping it to TX. Hope this helps.
Aug 06, 2010 | Acer AL2416WBSD 24" Monitor
Shows acer logo then blank screen and just goes from one to the other , power light flash on and off.
select f8 to enter advance menu. on advance menu
select last known good configuration. allow unit to boot. if this fails you will need to do a system repair with your windows disk.
Nov 14, 2009 | Acer AL1711M 17" LCD Monitor
It is all black, as if off
when starting windows press f8 key before the windows logo shows up > go to safe mode > click start>control panel> display>adapter>list all modes> choose 800x600 x 16 colours > apply > close > reboot to normal xp. OR When f8 key pressed > choose VGA mode. If this does not work then change the VGA Cable (borrow from someone if its TFT to test)
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Acer al1916 monitor goes black
You probably have a few dodgy caps on the power board inside. It's an easy fix if you are confident around electronics.
If not, pop it off to your local TV repair shop and have it taken care of now before it gets expensive with a complete failure.
Hope it helps =)
Apr 09, 2008 | Acer AL1916W 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1716 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
