Question about Friedrich Dehumidifiers
The units cuts out after a few minutes Then restarts after a whil e and the cuts out Again Friedrich dehumidifier QSO75CDA
  • molnarharris Jul 10, 2010
    answer did not relate to problem posted.
    Frigidaire model QSO75CDA
    units cuts out after a few seconds that it is powered on. A few minutes larter it will restart but will cut out again/
  • 2,272 Answers
The unit *always* uses "2 minute off" intervals *unless* the
room humidity is 15% or more below the target setting. If the room humidity
is, say, 6% or more below the target setting, then the unit will cycle on
and off, with the OFF intervals always being exactly 2 minutes.
the minimum "on interval" is also 2 minutes, then it seems
that, if the room humidity were substantially below target (say, 10% or
more, but less than 15% below target), then unit will eventually reach a
point where it will cycle on for 2 minutes on and then off for 2 minutes.
But if this was not happening before and just now started then its the problem of over-frost build up on coils of the humidifier it has to be cleaned from the coils by unplugging the unit from electric outlet. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
  • 677 Answers
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
Posted on Jul 09, 2010
Unit forms ice on back coil. Please advise
The freon in the unit is low. You probably have a leak.
Jul 13, 2014 | Friedrich D40 Dehumidifier
Power s on unit doesnt run no fan nothing
Mosr dehumidifiers have a switch that shuts the unit off when the water tank is full check this float to make sure it is not stuck in the off position also empty the tank if it is full.Hope this helps.
Dec 10, 2013 | Friedrich d70bp dehumidifier,70 pt.,115v
3 or 4 years old. the entire unit shuts of every 2 or three minutes. it stays off for a few seconds, then restarts
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
-0-0
Sep 11, 2011 | Friedrich D50C Dehumidifier
The entire unit shuts off and comes on again every 2 to 3 minutes. it is about 4years old.
heatman101
Why does the fan run non stop? the compressor runs and shuts off but the fan just runs on high and low. I have 3 other dehumidifiers that the fan runs only when the compressor runs...why doesnt the...
Depending on the time sequence you have this unit set to run, Fredrich's are designed so that the fan runs almost constantly, to keep the air moving. When it senses a rise in humidity above the level you have it set on, the compressor turns ON and runs until the level of humidity is lowered. This is especially true, if you are operating this unit in continual mode.
Hope this helps you and thanks for choosing FixYa.
Aug 14, 2011 | Friedrich D50C Dehumidifier
My D50C friedrich dehumidifier does not work. It runs - but will not extract the humidity from the air. It has only been used approx. 2 summers - no more - because last summer could not even run it. It...
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Jan 20, 2011 | Friedrich D50C Dehumidifier
Dehumidifier has shut down
The GFCI outlet needed to be reset. There was no problem with the dehumidifier itself.
Aug 01, 2009 | Friedrich D40C Dehumidifier
Haier dehumidifer HD656E
What you think it means is exactly what it does mean. When a running unit is shut off it should not be restarted until the system pressures have had time to balance out so the compressor can restart without difficulty.
Jun 18, 2008 | Haier 65-Pint Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
Dehumidifier turns off
Take out the fan motor and test it with direct power supply if it did not work more than 2 min,change the fan motor.
Jul 11, 2007 | Friedrich D50 Dehumidifier
Dehumidifiers Logo
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
