Question about RCA Scenium HD50LPW52 Replacement Lamp
I have a hd50lpw162 given to me. It has a dark uneven bar at the top that you can see the picture through an d the picture is dim. It had a lamp blow uo inside they replaced it , it worked for eight months and developed this problem. they thought it was a lamp again. they put new one in, the problem did not go away, What could be the problem, is it worth replacing
  • jspainville Jul 09, 2010
    Thank you i will try that does not seem to expensive to fix
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with take the lamp out and check the lamp switch, if everything appears to be working fine then it is the ballast which is the power supply source for the lamp which has gone bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 09, 2010
    Is this something i can replace. used to help my dad in his tv shop 20 years ago
  • Rylee Smith
    Rylee Smith Jul 09, 2010
    Yes if you have some expertise then you can do it yourself. You can buy it from this link
4 inch dark grey/blackish horizontal bar top quarter of screen.
If it had a fixed image of some sort that might also explain it---if you reopen a new question post the brand and model number.
May 31, 2012 | Televison & Video
RCA HD50LPW162 will not get bright
This model uses a lamp for brightness and average life is 2,000 hours or about 2 years--some lamps before failing will dim down.
Google the model number for common problems and to research this issue.
Mar 23, 2012 | Televison & Video
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
Dim picture...turned britness all the way up and picture is still dark...still color just dark...
The tv projection lamp life is ending.Replaced the tv projection lamp,will solved this problems.
Sep 08, 2010 | Philips 50P8341 50" Rear Projection...
Picture is dark
The projection lamp require changing.The lamp picture is dim the lamp is close to the end of it life.Require a new lamp.
Sep 01, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Everything works fine, just going dark on me!
Yes, anytime the picture becomes dim, or the color begins to fade it is time to replace the lamp.
Mar 17, 2010 | Eiki LC-SB20 Projector Multimedia...
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Compaq Presario Notebook
Acer screen looks dark?
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 23, 2009 | Acer Aspire 5315 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 07, 2009 | Acer Aspire 5040 Notebook
RCA Scenium HD50LPW52 Replacement Lamp Logo
54 people viewed this question
Top RCA Office Equipment & Supplies Experts
Electro Med Services...
Vladimir Frolov
ray gallant
Are you a RCA Office Equipment and Supply Expert? Answer questions, earn points and help others
