Question about Video Game Consoles & Games
I have a xbox not a xbox 360 and when you press the eject button the tray opens and then you press it again to close the tray it closes and then opens on its own its as if the eject button is stuck please can you help?
  • 13,433 Answers
Try pressing the eject button repeatedly, is it a little stuck?
Posted on Apr 19, 2008
What do I do it will not Except my games it just kicks them out
It looks like something is keeping the tray from closing all the way or the eject button is somehow being pressed when it closes. Open the tray and get a flash light to look inside to see if there is anything in there that shouldnt be (like maybe a disc that came loose from the tray and is still inside the xbox). If it looks all clear try holding down the eject button when putting the disc in. If that doesnt work try opening and closing it without a disc in. If it stays closed without a disc open and close it a couple times to be sure then try putting the disc in again. If that doesnt work try standing the xbox up on its side and putting the disc in.
The next step I would try is replacing the disc drive. This of course will void your warranty if you do it yourself I would suggest requesting repair from Microsoft if it is in warranty (http://support.xbox.com/en-US/xbox-360/repair/repair-process)
If it is not in warranty try replacing the disc drive (This is pretty complicated. I have done it and honestly wouldnt suggest doing it yourself unless you are very familiar with disassembling and resembling electronics.) Here are instructions http://hardandsoftgaming.wordpress.com/2011/03/12/replacing-a-faulty-xbox-360-dvd-drive-firmware-flash-or-circuit-board-transplant/
If you are not comfortably with doing this yourself find a local repair shop.
May 07, 2013 | Video Game Consoles & Games
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My xbox disc tray is not ejecting
If you lay your console flat press eject, then give the console a few raps (dont go mad) with your knuckles where the centre of the disk should be the draw will open.
let us know if this solution helps.
Jan 12, 2010 | Microsoft Xbox 360 Console
My xbox 360 cdrom won't keep
turn on your 360 and open the game drive. hold it open and turn of the 360. wait for it to power down completly. then turn the consel back on and it should close on its own now and stay closed as it should
Jan 07, 2010 | Video Game Consoles & Games
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Starting
xbox 360?
you open the disc tray by pressing the eject button directly above the tray, insert the disc and then close the disc in the same manner. if the game does not automatically start up then you will be required to go to the row that says My Xbox and the very first tab should say the game you have entered. you play it by pressing A
Jan 27, 2009 | Microsoft Xbox 360 Console
Xbox 360 draw fault
Try this, while the tray is closing press the eject button again. If that doesn't work you will need to replace the drive. buy the same model and move your logic board over to the replacement drive. It's paired with the xbox 360.
Dec 10, 2008 | Microsoft Xbox 360 Console
Xbox open/close disaster
u have the dvd rom damage y u dont try to change it
Aug 14, 2008 | Microsoft Xbox 360 Console
Disc Tray wont stay shut
A lot of people have this problem. Before you post, look around.
Anyway, I was able to call xbox 360 customer support. We did the troubleshooting but it still would not work, so they took my xbox 360 in for repairs. I would not try to fix it on your own because it might negate the warranty.
Xbox Support: 1-800-4MY-XBOX
Jun 22, 2008 | Microsoft Xbox 360 Console
Xbox 360
.... and why you press the button for close... only push the tray and enjoy your videogame
Nov 29, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
53 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
