Question about Nintendo Wii Console
Can't get Wii connected to internet wirelessly
Hi!
I've been trying to connect my Wii to the internet for awhile. I used the steps on the Wii, I've gone onto support.nintendo.com for assistance but it's not working. I have the router (with 3 antennae for the three floors) and the modem both in the basement and the Wii in the middle floor of the house. I tried the connection test many times and it still isn't working. I just tested it and it said Error Code: 51331. (I don't know if that will help :P)
    Genius:
  • 1,234 Answers
Error Code: 51331 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
Having trouble connecting my wii to the internet so i can use netflix
Here are step by step instructions on connecting your Nintendo Wii to the internet. Please note you must have a wireless internet connection available to you, the Nintendo Wii only connects to the internet via wireless signal.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Sep 04, 2011 | Nintendo Wii Console
Tip
How to connect your Nintendo Wii to the internet
In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
-Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
-Now select "Wii settings"
-Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
-Select "Connection 1: none"
-Select "Wireless Connection" then select "Search for An Access Point"
-Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
-Select the wireless access point you wish to use.
-If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
-Select "OK", then "Save Settings", and then "Yes".
At this point your Wii will now test the internet connection.
If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
I hope this guide has helped you connect your Wii to the internet. Enjoy!
Regards,
G33k
on May 13, 2011 | Nintendo Wii Console
How do u get internet on your wii
Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note you will need access to a wireless internet connection, or must have a wireless router in order to connect your Wii to the internet. The Wii only connects via wireless signal!
How to get the internet to the nintendo wii console
Hi. Welcome to fixya!
Hereis a step by step procedure on how to connect your Wii to the internet.
1. Turn on your Wii console and press the A Button on the Wii Remoteto reach the Wii main menu. Use the Wii Remote to select the "Wii"button.
2. Select "Wii Settings" to access the"Wii System Settings" menu.
3. Using the arrow on the right side of thescreen, scroll to page two and select "Internet."
4. Select "Connection 1: None"
5. Click on "Wireless Connection"and then "Search for an Access Point."
6. Select "OK" and the Wii willdisplay all the wireless networks it finds.
7. Select the wireless network that isyours.
8. If prompt to enter the security code,enter the security code that you have saved your router settings.
Jul 19, 2011 | Nintendo Wii Console
How do you connect the internet to the wii i have wireless in the house and it still wont connect
First, you have to go through the Internet connection setup process through the console and you've made no mention that you've attempted that so I wanted to make you aware of that. On the main menu, go to the lower left corner and click on the round Wii button. A new menu will appear with two options: Data Management and Wii Settings. Select Wii Settings. Go to the second page and choose Internet. Select Connection 1: None. Select Wireless Connection. Select Search For An Access Point. A network list will appear, select yours. You will then be prompted to enter the password/network key that you established when you set up your wireless router. The Wii will attempt to test the connection. If successful save your settings.
Second, simply because you have Wireless in the house it doesn't mean that it your wireless router has signal strength to reach the WIi. Various factors affect this including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
http://www.nintendo.com/consumer/systems/wii/en_na/online.jsp
May 08, 2011 | Nintendo Wii Console
Cant connect to wireless home hub
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
How do conect the wii to the internet?
Are you trying to connect by using a wired connection or a wireless connection?
For wireless:
  1. Click the Wii at the bottom left side of your screen.
  2. Click Wii Settings
  3. Click the arrow on the right side of your screen.
  4. Choose Internet.
  5. Choose Connection Settings.
  6. Choose Connection 1 to create a new connection.
  7. Choose Wireless Connection.
  8. Choose Search for an Access Point
  9. Click OK then choose the correct access point (where you connect to the Internet)
  10. Click OK to save the settings.
  11. After the test, if asked to perform a Wii System Update, choose Yes.
For wired: You need to purchase a Wii LAN adapter. Then the step are the same as above except step 7 you pick wired connection instead of wireless.
Comment if you have any questions.
Apr 07, 2011 | Computers & Internet
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    Wii internet
    When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge...
    Feb 19, 2009 | Nintendo Wii Console
    Connecting my wii to the internet
    to connect your wii to the internet connect to the following link or read the following instructions
    http://systemsetup.nintendo.com.au/Connecting_Online
    to connect your wii to the internet you will need to provide a wireless internet access point for it to find. you will need:
    a computer connected to broadband internet
    a wireless router OR Nintendo Wi-Fi USB Connector OR Wii LAN Adapter
    your wii console to be nearby all of the above
    If you are using the LAN Adapter you must plug the USB connection into the back of your wii console and the other end to your internet modems ethernet port. (follow steps below)
    if you are using a wireless connection follow steps below.
    Turn on your wii and on the main menu select 'wii' in the bottom left hand corner
    On the next screen, select 'wii settings'
    In the 'Wii System Settings', click on the blue arrow on the right to reach the second screen of options. On this screen, click the 'Internet' button.
    Select 'connection settings'
    select an open connection indicated by 'none'
    select the corresponding option, Wired or Wireless connection
    Wired:
    Wireless:
    Select the corresponding option, Search for an access point or Nintendo Wi-Fi USB Connector
    the wii will search for an access point, select the access point you wish to connect to, and save the settings
    The wii will now do a test connection and do a system update, the wii will now use that connection point to acces the online services
    hope i helped!!
    Sep 19, 2008 | Video Game Consoles & Games
    Nintendo Wii Console Logo
    76 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
