Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Mouse on computer runs away....cannot be controlled. The mouse is an optical mouse. All of the mouse properties have been checked, yet it still moves uncontrollably.
  • 76 Answers
Device Properties won't help you in this case. There is a connect button on your USB receiver and the mouse itself. Press the Connect button on the receiver, then press it on your mouse. It should make it stop moving randomly.
Posted on Jul 09, 2010
I have a microsoft intellipoint 5.0 optical mouse that has stopped moving the cursor. I have replaced the batteries, but the sending unit will not stay lit. I cannot do anything with my computer as I
take out the mouse part and fix it again. and click in control panel on mouse and in it cick on hardware and in hard wear click the properties and in properties click the power management
and then tick the option :
allow this device to bring the computer out of standby
Jan 14, 2012 | Computers & Internet
I have a gear head mouse, it's a lighted optical mouse model no OM3500U and I can't figure out how to change the batteries to see if that is the problem with it. It won't work at all and it...
There are no batteries in this mouse as it is a wired mouse. Wireless mice require batteries, not wired.Try removing the mouse from the USB port it is in and move it to another available port. It should work right away (after it detects the new device)but you may need to restart the computer after you move it to the new USB port. If that does not work, than it died.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Computers & Internet
My USB and windows vista does not recognize my new optical mouse from GE SKU# is 98543, my motherboard is an ASUS M2N-MX SE, my other optical mouse works fine but when i plug the RF receiver into the usb...
first check the battery inside the mouse make sure it is fully charged and well seated
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties hope this helps
Apr 01, 2011 | ASUS M2N-MX Motherboard
Mouse cursor will not function. Was working earlier today, did re-boot computer 7 times/change battery/etc. Seems to have lost pathway? Keyboard still functions
Check that it still has a good solid connection to the computer. If you are using a optical mouse, make sure the light is on. For a rolling ball, make sure the ball is in the mouse properly and that there is nothing inside to make it stick. Other than that, you may need a new mouse.
Feb 24, 2011 | Computers & Internet
I have an older HP desktop and just added a new HP wirewless optical mobile mouse with usb. They seemed to work fine initially but then I needed to move the computer so everything was shut down and moved...
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | HP Wireless Optical Mouse
The cursor moves back and forth and up and down Ok but skips badly when moving diagonally. Cordless Optical Mouse
control panel, mouse properties, pointer options, snap to option... may be checked
see if the other options are ok test them out and see....
Jul 30, 2009 | Computers & Internet
Buttons dont work like they did
You can try accessing mouse properties in Control Panel and check, change the button configuration on the button tab.
To access mouse properties, click Start, then Control Panel, double click Mouse, then the buttons tab.
Feb 18, 2009 | Logitech Optical Marble Mouse USB PS/2
Microsoft 4000 optical mouse
Try this - Go to control panel > mouse > hardware tab > properties > power management tab
Make sure the entry "Allow this device to bring the computer out of standby" is checked.
If you meant that your screen saver doesnt come on because the mouse is plugged in, it could be because the surface on which your mouse is rested is uneven or extremely smooth, causing the mouse to move, or that the mouse sensitivity properties are set very high. When not in use, try placing the mouse on a piece of dark cloth and see if this helps. Or in the steps mentioned above, make sure "Allow this device to bring the computer out of standby" is UNchecked. Note that you cannot use the mouse to get out of screen saver mode in this option. you will have to tap the spacebar..
Let me know how it goes.
Nov 05, 2008 | Microsoft Wireless Optical Notebook Mouse...
Wireless mouse issues help
This information is straight off of Logitech's help forum. To change the channel a mouse is using, simply press the connect button on the receiver and then press the connect button on the bottom of the mouse. You can check the channel status in the MouseWare Properties under the Cordless Tab. You may also try to keep the distance between systems at least 10 feet or more. Moving the mouse closer to or further away from the receiver can also improve transmission and performance. If the above fails, try pressing and holding the "Connect" button on the receiver for 10 seconds. This will reset the receiver's connection information and allow you to do a first time connection with the receiver and mouse. After holding the Connect button for 10 seconds, press the Connect button on the bottom of the mouse to synchronize it with the receiver. Good Luck.
Jun 10, 2007 | Logitech Cordless Click! Plus Mouse
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
93 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
